Latest: heikkisj
Overall: 17126
Online Now [60]:
Visitors: 59
Today: 16768
Total: 100195398
Forums › The Car › Solved 206 Problems › Gearbox noise dissapears when pressing clutch pedal [UPDATE]
PostPosted: Sat Apr 14, 2012 2:27 am Up
As title says.
Rattling noise (ball-bearing?) but my mech recons it's not the clutch release as that would make noise when pressing pedal.
It was also replaced along with the clutch plate/disk about a year ago (genuine pug).
So what is it exactly?
Cheers.
UPDATE - Page 2.
ARRAN
PostPosted: Sat Apr 14, 2012 2:30 am Up
Mine did this for ages, and my gearbox went Monday.
See my project here.
PostPosted: Sat Apr 14, 2012 2:32 am Up
Nice.
shell-vt
Trade Rating: +46
possable thrust bearing?
york 16,3
PostPosted: Sat Apr 14, 2012 2:34 am Up
OK, where exactly is that?
Is that on the crank-shaft?
lenbt
PostPosted: Sat Apr 14, 2012 2:50 am Up
same as the release bearing, mine does it too. and used to to it on my 106 until i couldn't bare it anymore so had the clutch and release bearing changed.
PostPosted: Sat Apr 14, 2012 3:05 am Up
Damn.
Not pleased if it's this as it was fitted new and genuine about a year ago.
Deckchair5
It's logical to expect the clutch release bearing to make most of the noise when depressing it as that's when it's under load but it can rattle in its cage when fully up and can squeal when worn and under very light load when pedal is fully up
Sometimes if you pull the clutch lever on the gearbox even fuller back from the rest position and the noise stops then you know what it is for certain
PostPosted: Sat Apr 14, 2012 3:09 am Up
So are you saying it could be the release bearing even though it stops when pedal is pressed?
Not pleased if it's this as it was fitted new and genuine (Valeo) about a year ago.
Deckchair5
PostPosted: Sat Apr 14, 2012 3:17 am Up
Yes, especially a loose rattling in its cage or a squealing when cold which lessens as it warms up
A rattling or chattering is just that though and they have been known to stop doing it on their own as the release bearing is just catching at the rest position. Try pulling the lever back a bit further and see if it stops then you'll know and you can show your mechanic
PostPosted: Sat Apr 14, 2012 4:27 am Up
How can I pull the lever back if the clutch cable is preventing it?
Also, it only stops when fully depressing pedal and only does it 3 out of 5 times at varying level of noise.
Cheers for replies all.
Deckchair5
PostPosted: Sat Apr 14, 2012 5:04 am Up
The cable should never be pulling so tight that there is no slack at all at the lever when pedal is fully up
206 clutch cable
PostPosted: Sat Apr 14, 2012 5:10 am Up
OK. 'Will check. Thanks.
kit325
PostPosted: Sat Apr 14, 2012 6:23 am Up
Clutch cable are self adjusting due to the design of it (self adjusting mechanism) U better dun touch it, once u remove it, will be pain in the butt to put it right again.
I am sure will be the bearing for the clutch cause i have similar problem and it gone when i replace with complete clutch kit.
After u warm up the car or drive for some distance will it get better?
kit
Deckchair5
PostPosted: Sat Apr 14, 2012 6:32 am Up
Now don't make the guy paranoid Very Happy
No one said anything about removing cables, just checking for the 5mm or so of slack which the self adjusting cable should automatically put into the system. It's how you check that the cable's been installed and adjusting correctly
