Latest: tbafonso
Overall: 17130
Online Now [187]:
Visitors: 186
Today: 60321
Total: 103569512
Forums › The Car › 206 Problems › scrubbing noise
scrubbing noise
dj71
PostPosted: Sat Apr 14, 2012 7:47 am Up
i have an intermittent scrubbing or whining noise coming from front end of car at around 40-50 mph cant locate exactly where the noise is coming from, thought it might have been brake dics catching as they looked pretty worn with a deep lip on outer edge renewed these and pads but still have the noise, any ideas's b4 i start changing things like drive shafts unnecessarily?
thanks guys
dj71
dj71
PostPosted: Wed Apr 18, 2012 8:49 am Up
drive shafts replaced but noise still there, is it possible to be alternator / steering pump bearings maybe tensioner pully, cud do with sum idea's
dj71
frankaai
PostPosted: Wed Apr 18, 2012 8:56 am Up
could be wheel bearing mate, i had same problem on the rear, is it quite loud?
frankaai
PostPosted: Wed Apr 18, 2012 8:57 am Up
if i was you i would jack each side up and spin each wheel by hand and see which one is making the noise
