Online Now [630]:
Visitors: 629
Today: 130785
Total: 157008518
Forums › The Car › 206 Problems › Brakes!!!
Brakes!!!
Tann206
PostPosted: Sat Apr 14, 2012 11:46 am Up
is there any way you can bleed drum breaks without using the grease nipple as it has sheared off?
o
macj
PostPosted: Sat Apr 14, 2012 11:47 am Up
nope....... best get it fitted with a new wheel cylinder. They are not very expensive
Tann206
PostPosted: Sat Apr 14, 2012 11:50 am Up
will i not need to bleed the brakes after refitting the new cylinder though?
o
dj71
PostPosted: Sat Apr 14, 2012 11:59 am Up
yer, the new cylinder will have a new bleed nipple
dj71
PostPosted: Sat Apr 14, 2012 12:06 pm Up
you have to bleed through the nipple,other wise the air will stay inside,try to get a new nipple from an old cylinder,or replace it all
PostPosted: Sun Apr 15, 2012 1:10 pm Up
You can mess about for ages trying to get the old nipple out but they are buggers once seized and broken. By a new cylinder (as above they are not expensive) and a brake hose clamp as that will minimise fluid loss and make bleeding the system much easier.
New cylinders can be bought for less than £15 - definitely not worth faffing about with the old one.
