Online Now [502]:
Visitors: 501
Today: 132017
Total: 157599211
Forums › The Car › 206 Problems › Front Window Wiper Problem
Nyto206
PostPosted: Mon Apr 16, 2012 9:22 am Up
Hi all
I was driving down the orad in heavy rain the other day and the front window wipers got stuck when i pulled over and got out and manually pulled them apart they looked fine. But when trying to operate the switch on the stalk, only one wiper was moving (the passenger one) Both washers work and the back wiper and washer works fine too.
Any ideas or ways to fix this!
cheers
Nyto Pug 206
davecuk
PostPosted: Mon Apr 16, 2012 10:21 am Up
hi. seems like one of the wiper linkages under the bonnet may have come off, worth a check there.apparently there was a problem with this and a recall. sure Lee will put you right as to the details of this. Dave
206 1.9 d silver
PostPosted: Mon Apr 16, 2012 10:40 am Up
As with all problems it's best to look at the most basic possibility.
Tighten the nut at the bottom of the wiper arm?
