Latest: Worthy967
Overall: 17143
Online Now [561]:
Visitors: 560
Today: 117087
Total: 115602066
Forums › The Car › 206 Problems › Coolant Error Question
matt-19
PostPosted: Tue Apr 17, 2012 3:23 am Up
Hi all,
Quick question about coolant.
My car has started beeping shortly after starting the engine. a red light comes on the lower right of the dash (I've looked in the handbook and this is where the coolant warning light is located but it's gone again so fast that it's hard to be sure).
Yesterday I had a message flash up on the radio display which again appeared and disappeared again straight away but I think I caught the words "top up" & "coolant".
Is there a way to check the coolant level manually? I've had a look at the bottle I can't see any level markings on it.
Just wondering if I should top it up anyway and if so would tap water be ok or do I need to buy some special coolant?
Many thanks for your help
Matt
206 HDi 90BHP 54 reg
devotedsniper
PostPosted: Tue Apr 17, 2012 3:28 am Up
The best way to check is to shine a small light on the bottle, look into the coolant bottle and slowly move it up, when the coolant stops being illuminated you've reached the top of the coolant level, if it's in the middle of the bottle then your about right.
Or at least thats how i do it because my bottles stained on me 1.4, just don't fill it up to the top.
Now a 2010 Renault Megane Coupe owner
PostPosted: Tue Apr 17, 2012 5:50 am Up
Squeeze the radiator hose while looking into the reservoir.
matt-19
PostPosted: Tue Apr 17, 2012 8:53 am Up
That's brilliant thanks, will normal water be ok to use?
