Latest: Andyblue64
Overall: 17123
Online Now [567]:
Visitors: 566
Today: 34919
Total: 98122143
Forums › The Car › 206 Problems › exhaust rubbers
exhaust rubbers
donkeyding
PostPosted: Thu Apr 19, 2012 3:51 pm Up
Well recieved my polyflex ones and they are awesome!!!
Massively improve the hight of the exhaust and stops the flex under load now. Really happy with them and at under a £5 a piece a good buy!!!
Measurements are 70mmX50mm and are near as identicle as the oem ones
Deffo worth the money. Got them from ruderacing and recieved them next day to so even better!!!
Hope it helps some people
Cheers
Dave
spike_202
PostPosted: Thu Apr 19, 2012 4:03 pm Up
under £5? all the ones i see are £5.23??
**spike's project**
TEAM:+200bhp
donkeyding
PostPosted: Thu Apr 19, 2012 4:11 pm Up
They have took them off at that price.
Just got my invoice out.
£13.83 inc VAT and delivery!!
Robbing wanks putting there prices up!!!!
Well worth it tho pal Smile
Dave
gazza82
PostPosted: Mon Apr 23, 2012 1:01 pm Up
You might find they had to replace their stock and the new ones cost them more!
Think a couple of my Alfa's powerflex hangers came from them .. the rest I just hunted for the best price on fleabay.
Avoid Halfrauds if you don't want to get royally ripped off on Powerflex parts ...
DeadEyePaul
PostPosted: Mon Apr 23, 2012 1:03 pm Up
Either that or they have seen the post on here and we are advertising their business
Rob2859
PostPosted: Mon Apr 23, 2012 6:02 pm Up
Remember they won't make the car handle better just because they are stiffer and say performance on them Rolling On The Floor Laughing
In my experience the Halfords ones are crap. Two snapped and they kept slipping off.
spike_202
PostPosted: Tue Apr 24, 2012 1:05 pm Up
lol as they are not part of the susspention, its just when i floor it as it, it moves. just wanted to stop the exhaust moving when i give it some Wink
**spike's project**
TEAM:+200bhp
donkeyding
PostPosted: Tue Apr 24, 2012 3:25 pm Up
Mine have been awesome since being on the car!!
Not had any slip and has held the exhaust
Much higher. Deffo recommend them worthy upgrade
Cheers
Dave
Stigter
PostPosted: Wed Apr 25, 2012 12:56 pm Up
Gutted - I bought them without checking - the side where they attach to the car it fits - but to the exhaust I don't think it will as quite a bit bigger
any advice?
Can\'t be blank
PostPosted: Wed Apr 25, 2012 2:35 pm Up
Then stop the engine moving so much with stiffer mounts.
DeadEyePaul
PostPosted: Wed Apr 25, 2012 2:37 pm Up
any advice?
It's just stiff rubber it will stretch stick some lube on there Very Happy
Jammie_1989
PostPosted: Wed Apr 25, 2012 3:02 pm Up
Will they fit a 180? My exhaust is hanging a little lower than I would like
206 gti 180
donkeyding
PostPosted: Wed Apr 25, 2012 3:17 pm Up
Yeh pal cant see why not.
There universal fitment.
Stigter..... Just use a little lube to persuade it on Smile
Dave
Jammie_1989
PostPosted: Wed Apr 25, 2012 3:29 pm Up
Which EXH no did you go for on ruderacing?
206 gti 180
Stigter
PostPosted: Wed Apr 25, 2012 3:39 pm Up
I bought these:
but the reason I don't think they will fit is because on my backbox it has a larger diameter then what is on these hangers
if you look at these on ebay: www.ebay.co.uk/itm/Peu...4d003d04c9
You can see there is a difference between the two holes.
Can\'t be blank
Page 2 of 3
