Latest: sparrowdclxvi
Overall: 17139
Online Now [203]:
Visitors: 202
Today: 19007
Total: 113090531
Forums › The Car › 206 Problems › towbar relay power
towbar relay power
stonster
PostPosted: Mon Apr 23, 2012 11:09 am Up
Hi all,
First post, so be kind! Does anyone have a 206 with 7-way bypass relay? I know I probably need to run a new power cable from the battery to the bypass relay in the boot. I can find a cable loom that I can run alongside inside the car from the boot to the front bulkhead. Only snag is how do I get the cable through the bulkhead? All the loom has got a big gromit through into the engine bay and I can't get another cable through.... do I need to drill a hole in the front bulkhead? Anyone any ideas?
Thanks!
stonster
parkesie
PostPosted: Mon Apr 23, 2012 11:26 am Up
I ran mine off the 12v socket in the boot.
Signature p**s
stonster
PostPosted: Mon Apr 23, 2012 11:46 am Up
was that an SW? Sadly mine is just a standard 3dr and doesn't have a 12v in the boot....
thanks tho!
stonster
parkesie
PostPosted: Mon Apr 23, 2012 11:57 am Up
Yeah an sw have a look in the ice section on here for amp wiring should be able to use the same route for a live feed.
Signature p**s
mtempsch
PostPosted: Mon Apr 23, 2012 11:58 am Up
stonster wrote:
Hi all,
Thanks!
Multiple threads in the HOWTO: ICE section cover this, for instance this thread (clicky)
Silvermetallic 2004 206 RC
stonster
PostPosted: Mon Apr 23, 2012 12:10 pm Up
Winner - just what I wanted!
stonster
