Online Now [1765]:
Visitors: 1765
Today: 122189
Total: 152162636
Forums › The Car › 206 Problems › Manifold blowing
Manifold blowing
Kelz
PostPosted: Sat Apr 21, 2012 5:11 pm Up
I think the manifold on my gti is blowing but not 100% sure... Was low on oil and started to sound tappity so done a oil nd filter change and seemed better but since then when I'm driving and put my foot down a little to,accelerate that's when you hear the noise, think its the manifold blowing but not,sure... Is this a common problem or not likely?
Kelz!
PostPosted: Sat Apr 21, 2012 7:10 pm Up
Mine is blowing. Rattles like hell.
Kelz
PostPosted: Tue Apr 24, 2012 5:11 am Up
Hmm possibly same thing then lol
Kelz!
rick-gti
PostPosted: Tue Apr 24, 2012 5:27 am Up
The exhaust manifold on some gti's rattle, they need to be welded. there's 4 pipes that loosen and cause the rattle. Very poor and s**te design. Ive just welded mine as it rattled like fook over 2000 rpm.
clio 197sport owner
PostPosted: Tue Apr 24, 2012 5:49 am Up
Exhaust manifold rattle is a common problem on the EW10J4 lump, mate of mine has a 307 with the same engine fitted & had to weld his manifold to because of the annoying rattle issuse Laughing
Kelz
PostPosted: Tue Apr 24, 2012 6:58 am Up
will upgrading to a 4-1 or 4-2-1 solve this?
Kelz!
rick-gti
PostPosted: Tue Apr 24, 2012 7:02 am Up
Fitting a stainless manifold will stop it yes, but as said in another thread i believe you started they are a pain to fit and the cat needs to be cut. Im welding mine as i have the engine out Smile
clio 197sport owner
Kelz
PostPosted: Tue Apr 24, 2012 7:05 am Up
lol the welding isn't a issue as i have family in the welding trade
i may just put up with it for now and then upgrade further into the year lol
Kelz!
rick-gti
PostPosted: Tue Apr 24, 2012 7:11 am Up
If you plan on keeping the car then get it done, i beleive you can remove the manifold by undoing the lower engine mount and pulling the engine foward. Then weld the 4 pipes here:
clio 197sport owner
Kelz
PostPosted: Tue Apr 24, 2012 7:17 am Up
the pipes inside?
would this cause the car to lose any power if they are lose and blowing?
Kelz!
rick-gti
PostPosted: Tue Apr 24, 2012 7:34 am Up
The 4 pipes are what rattle, i put a small tack weld on each. This wouldnt cause a loss of power and if its blowing you need to check the seal from the manifold to the cat.
clio 197sport owner
PostPosted: Tue Apr 24, 2012 2:36 pm Up
Kelz wrote:
the pipes inside?
yes the pipes inside, Nope it wont lose any power, its just very annoying as it rattles between 2k & 3k rpm Laughing
