Online Now [55]:
Visitors: 54
Today: 22569
Total: 116674388
Forums › The Car › 206 Problems › Gear change catching
mlambie
PostPosted: Tue Apr 24, 2012 9:30 am Up
Hi i have a 206 sport 1.4... Had a gearbox oil leak for a while before i bought the car, had the seal repaired and now changing gears especially the first gear mainly catches and is difficult to get in at 2-3000 + revs. At low revs is nearly fine.
Any help would be appreciated.
PostPosted: Tue Apr 24, 2012 2:07 pm Up
You have a Faulty clutch Pressure Plate,so to fix it,you have to replace this plate with a new one.
mlambie
PostPosted: Wed Apr 25, 2012 1:16 am Up
Cheers for advice am going garage today....
mark
PostPosted: Wed Apr 25, 2012 2:04 am Up
From bitter experience:
Any other gearbox oil other than OEM (Total BV 75W80 non-synth) is a complete nightmare with MA box.
I have even used "PSA approved 75W80 Valvolene" and it was hopeless.
THE most important thing regarding the MA box is to put the exact oil specified by pug, and then it's perfect.
You'll see.
mlambie
PostPosted: Thu Apr 26, 2012 1:24 am Up
Thanks for the responses
Ok I took it to the garage that repaired the gearbox oil leak seal... they said its not there problem and couldn't say what the probably was and they didn't touch the gearbox anyway????
Gonna take to peugeot monday, only had it a month and its a 2006 model.
mark
PostPosted: Thu Apr 26, 2012 3:21 am Up
How could a gearbox leak be fixed without touching the gearbox?
And how come you now have the EXACT behaviour of incorrect gearbox oil?
Just sayin'.
mlambie
PostPosted: Thu Apr 26, 2012 4:30 am Up
They put in 75 90.
Just a 'top up' they said. taking to peugeot on monday but am worried that i may do further damage driving as is?
mark
PostPosted: Thu Apr 26, 2012 6:02 am Up
No damage has or will occur.
But it's not enough to put any 75W80 in there.
It must be Total "BV" which is 75W80 non-synth and is what dealers are supposed to put in.
It was designed specificaly for the MA box and works perfectly with it.
Anything else and the synchro rings don't slip properly, either too much or too little.
Also, give it 10 miles or so to rinse and settle.
PostPosted: Thu Apr 26, 2012 6:05 am Up
75w/90 always gave s*** gear change
PostPosted: Thu Apr 26, 2012 6:14 am Up
Done that, then put Valvolene 75W80 for PSA only supossedly, and it was even worse.
I had to pray to put 1st gear every time. The rest of the gears I swore.
mlambie
PostPosted: Thu Apr 26, 2012 12:48 pm Up
Thanks again.
Will tell the mechanic monday... hope to enjoy the drive again
mark
PostPosted: Thu Apr 26, 2012 1:00 pm Up
well you need to read the spec more in depth.
if you check the BV75/80; Viscosity at 100 is 8 and at 40 is 49;
durablend is 9.2 and 60.6;
even motul 75w-80 has 10.1 and 58.8
miller 75w/80 10.4 and 74.9.
see the difference?
they all claim to meet or excess PSA spec Laughing
but time has proved which is right and which is wrong
synchro need the right thickness of oil to work properly.
mlambie
PostPosted: Sun Apr 29, 2012 11:33 am Up
Thanks for advice
mark
