Online Now [489]:
Visitors: 488
Today: 138235
Total: 157605373
Forums › The Car › 206 Problems › 2002 Pug 206 1.4 HDI Tapping noise when cold.
richardsoc
PostPosted: Tue May 01, 2012 7:25 am Up
Hi i have a 2002 206 1.4 HDI with 75K miles on it. And it has a Loud tapping noise on tick over and when Reved. I took it to the local garage but by the time i got there the car had stopped doing it. Which makes me belive It only does it when cold.
Some people say it could be a lift or Pulley. any known faults. ?
Many thanks
206 1.4 HDI
richardsoc
PostPosted: Tue May 01, 2012 7:26 am Up
Forgot to say the noise sounds to be to the o/s of engine around the cambelt area.
206 1.4 HDI
rick-gti
PostPosted: Tue May 01, 2012 7:44 am Up
Is the oil level ok? Could try an oil change and maybe topend treatment. When was the cambelt last changed?
clio 197sport owner
richardsoc
PostPosted: Tue May 01, 2012 7:54 am Up
Cambelt changed 2 years ago and all oil ok. :/ someone evan said that its normal as its the 1.4 Engine they all do it untill they get hot. What i cant believe.
206 1.4 HDI
glenpring
PostPosted: Tue May 01, 2012 8:54 am Up
is it a tapping or kinda chuffing noise??
richardsoc
PostPosted: Tue May 01, 2012 9:02 am Up
I would ay tapping noise. ?
206 1.4 HDI
sulli
PostPosted: Tue May 01, 2012 2:58 pm Up
I have the 1.4 hdi engine in mine, can confirm no tapping from it :/
206 VAN SILVER!
www.Sheffield-WebDesigns.co.uk - discount for 206info members!!
www.HealthyCigs.co.uk - discount for 206info members!! quote - 206info
cosmicdance
PostPosted: Thu May 03, 2012 12:19 am Up
There is a common fault with the crankshaft pulley but if yours is stopping the tapping when it's warm then it can't be that.
I had the crankshaft pulley replaced on mine and it used to do it when both cold and warm.
When was the engine oil last changed?
If it is too old and worn out then it won't help with tapping when cold.
Andy
Andy
cosmicdance
PostPosted: Thu May 03, 2012 12:24 am Up
Andy
Andy
