Latest: elelectricistadeMateo
Overall: 17127
Online Now [73]:
Visitors: 72
Today: 5157
Total: 100403382
Forums › The Car › 206 Talk › Oil temp sensor
Oil temp sensor
donkeyding
PostPosted: Tue May 01, 2012 2:13 pm Up
Evening folks
Im going to fit a oil pressure gauge but i need to put on the sender for it.
Now i have thought that the ideal place would put in a t-piece into the block where the oil temp switch is at the moment.
Question........ Where is this located on the block???
Would this work fine???
Any ideal what the thread size is so that i can get the t-piece???
Cheers
Dave
donkeyding
PostPosted: Tue May 01, 2012 3:36 pm Up
No one???
Dave
PostPosted: Tue May 01, 2012 11:43 pm Up
There should be provision for this already on the block.
Either a blanked-off threaded hole, or replacement of the oil-pressure switch with dual-purpose
temp&pressure or something.
Also look for an extra hanging connector in the lower engine bay.
You will need BSI update as well.
donkeyding
PostPosted: Wed May 02, 2012 12:46 am Up
I don't have bsi as far as im aware with it being pre-plexed.
Thats right isnt it???
Cheers
Dave
PostPosted: Wed May 02, 2012 1:02 am Up
All cars have a BSI.
donkeyding
PostPosted: Wed May 02, 2012 1:57 am Up
So would this need a reconfig then for adding a pressure gauge??
Lee in sure ul be the man to educate!!!
Cheers
Dave
PostPosted: Wed May 02, 2012 3:17 am Up
donkeyding wrote:
Lee I'm sure ul be the man to educate!!!
Cheers
Dave
Smile
donkeyding
PostPosted: Wed May 02, 2012 4:11 am Up
Dont know if i made my self clear to the point.
I will be putting a seperate sender for the pressure gauge. Hense the reason y i cant understand why the bsi would be affected in any way???
Eductation needed plz
Dave
PostPosted: Wed May 02, 2012 6:59 am Up
There's two ways you can go about this;
1) using an aftermarket seperate dial which takes it's signal directly from the sensor so to speak.
2) Many 206 clusters (dials unit) already have provision for temp readout. By updating the BSI
(cabin electronics control module under the steering wheel) you can add an extra sensor on a pre-existing
hole on the engine block and have a readout on the cluster. Most of the time though you have to change
the cluster as well to one that has this which is a hassle.
Or you can forget the whole thing and always take care of your oil quantity/quality etc.
I would recomend Total Quartz 9000 or Shell Helix Ultra 5W40, both fully synthetic but someone
might correct me on this for a 138.
PostPosted: Wed May 02, 2012 11:32 am Up
Dont see the point in a pressure guage. If it drops too low your engine is already knackered.
PostPosted: Wed May 02, 2012 1:42 pm Up
He wants oil-temp gauge I think.
PostPosted: Wed May 02, 2012 2:07 pm Up
Peugeot were kind enough to fit an oil pressure warning system to the car.When the red light comes on, the pressure is too low. Simple and effective so no point messing around with it really.
donkeyding
PostPosted: Wed May 02, 2012 2:45 pm Up
No its deffo the oil pressure that i want.
My car isnt a show car and no means ever will be! Its used as a daily hog, some spirited driving on a weekend and the odd gew track days. Soo there fore nothing wrong with being aware of what exactly going on.
As said in other threads each to there own. I like them n i want one so there Smile it's going to be a smoked gauge so black when the engine is off and a stepper gauge. After market of course
Soo best option without messing with the bsi is to put in the t-peice where the oil temp sensor is on sump?? Or is there some where else i can attach to on the block???
Cheers
Dave
PostPosted: Wed May 02, 2012 3:26 pm Up
I'm fairly sure that the oil pressure in the sump will be minimal as gravity pulls the oil into it. You need to find the oil pressure sensor on the engine and put the t piece there.. If done properly then gauges look ok.
My ex's son decided to put one on his car, didn't know what he was doing . Next day I was sourcing a replacement engine as all the oil wason the outside of the engine block. The gauge was just an expensive dial on the dash by the time I finished fitting the engine. Looked better than the hole it would have left.
simpsonrc
PostPosted: Wed May 02, 2012 3:43 pm Up
It will not work in the sump, best to put it where the standard oil presser gauge is on a t-piece just above the oil filter.
