Posted: Mon May 07, 2012 3:06 pm |
The previous owner of my 206 damaged the tailgate and i have finally got round to buying a new one.
Does anyone know of a decent guide to removing them?
thanks.
Posted: Mon May 07, 2012 3:13 pm |
This is probably one of the easiest things to do. You dont even need any tools.
Pull back the carpet from behind the lights in the boot.
Locate the butterfly nut.
Unscrew it.
Pull the light out.
Put new light in.
Do the butterfly nut up.
Put the carpet back.
Job done.
Posted: Mon May 07, 2012 3:16 pm |
craigy00craig wrote: |
Unscrew it.
Pull the light out.
Put new light in.
Job done. |
Huh?
Disconnect the multiplug on the n/s
Remove the third brake light, 2 10mm nuts
Remove the two struts, pop off with a flat bladed screw driver
Then remove the 4 13mm nuts holding the tailgate on
10 mins tops
Posted: Mon May 07, 2012 3:26 pm |
what about the rubber tube on the top right?
im guessing that is the water supply for rear wiper?
just yank it? lol
Posted: Mon May 07, 2012 3:37 pm |
Yeah, it'll come out when you take out the brake light
Posted: Mon May 07, 2012 3:44 pm |
at risk of sounding like an idiot, what do you mean?
I dont need to do anything to the 3rd brake light do i? i got a 2nd hand tailgate so its got all that stuff already on it.
cheers
Posted: Mon May 07, 2012 3:50 pm |
thought it said tail lights lol
It need's to come out as the pipe is still connected to it.
Posted: Mon May 07, 2012 3:54 pm |
Tail gate (BOOT) is like two to Four bolts, still simples.
| +3 postive seller feedback! | |
Posted: Mon May 07, 2012 4:03 pm |
Ivejust changed mine. Pm me if you want info. I hope your new boot came with the wire loom, or it's a ballache to rewire( I had to!!)
Posted: Mon May 07, 2012 4:49 pm |
yeah its got the wiring but its the small tube on the right im confused about.
cheers
Posted: Thu May 10, 2012 5:29 pm |
What about SW models?
Posted: Sat May 12, 2012 4:11 am |
Get a friend to help hold the tailgate while you bolt it up, bit of a handful otherwise, I balanced mine on my head!! lol
