Posted: Tue May 08, 2012 5:40 am |
We where talking to Turbo Technics last week & they quoted around £1100 to supply & fit a service / exchange unit.
DV6 turbo exchange isnt just bolt a new turbo on, there is a lot of other engine work that needs doing unless you want the replacement turbo to fail very quickly.
Posted: Tue May 08, 2012 5:45 am |
MrBSI wrote: |
DV6 turbo exchange isnt just bolt a new turbo on, there is a lot of other engine work that needs doing unless you want the replacement turbo to fail very quickly. |
ok i didn't realized it cost that much
i always presume is the oil feeder pipe got blocked and then boom....
Posted: Tue May 08, 2012 5:46 am |
Thats still cheaper then a service / exchange unit from Peugeot / Citroen as a part only
Posted: Tue May 08, 2012 5:56 am |
well if mine is the original, it has done 112k so is about due for renewal.
Posted: Tue May 08, 2012 6:11 am |
Trade Rating: +59
Ghosty wrote: |
well if mine is the original, it has done 112k so is about due for renewal. |
If you use the wrong grade of oil, you risk knackering the turbo. If it ain't broke, don't fix it (but on a DV6, I'd prepare for the worst )
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Tue May 08, 2012 6:41 am |
Mine was replaced in August last year with new feed and return pipes so fingers crossed!
Posted: Tue May 08, 2012 6:49 am |
darratt78 wrote: |
Mine was replaced in August last year with new feed and return pipes so fingers crossed! |
pub quiz, what oil should you use?
Posted: Tue May 08, 2012 6:58 am |
Would be very interested to know..... Will do an oil change at some point this year. No-one can agree on this forum what grade is best!
Posted: Tue May 08, 2012 7:41 am |
darratt78 wrote: |
Would be very interested to know..... Will do an oil change at some point this year. No-one can agree on this forum what grade is best! |
you need ACEA C2 or C3 oil (low ash)
and usually they only came in 5w/30.
you are not recommanded to use oil for let say TU5 or EW10 or DW10 engine.
Posted: Tue May 08, 2012 7:48 am |
thanks seabrook, i was thinking of an oil change come the end of the month, will have to make sure correct oil is used
Posted: Tue May 08, 2012 12:12 pm |
Cheers seabrook, I'm guessing Mobil 1 ESP or castrol edge might be a good shout. Will be heading to Gsf or euro for that though, ain't getting mugged up in halfords!
Posted: Tue May 08, 2012 1:29 pm |
darratt78 wrote: |
Cheers seabrook, I'm guessing Mobil 1 ESP or castrol edge might be a good shout. Will be heading to Gsf or euro for that though, ain't getting mugged up in halfords! |
ESP is fine, but castrol edge comes in different grade so you better check the label.
