Posted: Thu May 10, 2012 12:59 am |
Posted: Thu May 10, 2012 2:11 am |
Is it me or does that screaaam.
Posted: Thu May 10, 2012 2:48 am |
Sounds like original '90s Vtec to me.
Posted: Thu May 10, 2012 2:56 am |
Posted: Thu May 10, 2012 1:07 pm |
V9977 wrote: |
8O
Sounds like original '90s Vtec to me. |
You kidding, Right ?
| 2005 206 RC RED
Lot's of CNC machined customs pars. | |
Posted: Thu May 10, 2012 2:20 pm |
Schumi wrote: |
V9977 wrote: |
8O
You kidding, Right ? |
Nope.. www.youtube.com/watch?v=XCCBX6-k0UU
And I was old enough back then to drive one.
More harmonics but it certainly reminded me of it.
Posted: Wed May 25, 2016 7:15 pm |
HI, HOW ARE YOU? MY NAME IS DANIEL FROM CHILE. I HAVE A 206 RC TURBO, TO THE EGINE MANAGEMENT I HAVE A AEM FIC, BUT THE OEM ECU CAUSE MANY PROBLEMS. I READ THAT YOU KNOW ABOUT THIS. I WANT INSTALL A STAND ALONE ECU, BUT WHEN I TRY STOPPED WORKED THE PANEL AND LIGHTS. PLEASE IF YOU KNOW HOW SOLVE THIS PLEASE HELP ME.
REGARDS
DANIEL
Posted: Thu May 26, 2016 2:33 am |
Is that being ran on the standard ECU?
What problems are you having?
Sounds awesome
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Thu May 26, 2016 10:52 am |
i need install a stand alone ECU in my gti 180, but i dont want lose the funtion of the panel instrument and the headlight. When installing the stand alone ECU i disconnected the sensors from the original ECU to engage them in the stand alone ECU, but i lost the operation of the instrument panel and headlight. i want change the ECU but keep the normal funtion of the car (instrument panel, headlight, A/C, etc and did not throw errors the bsi).
i know that is possible, but i dont know how.
thanks
Posted: Thu May 26, 2016 1:40 pm |
You need to keep at least the crank sensor connected to fool the ecu into thinking it still controls the engine.
