Online Now [484]:
Visitors: 483
Today: 123385
Total: 156475674
Forums › The Car › 206 Problems › 206 GTI 180 steering issue
slymambo
PostPosted: Thu May 10, 2012 11:43 am Up
Quick question for anyone who can help, ive been having some trouble with the steering alinement on my 206 gti for awhile now so went to get the wheels balanced and get the tracking sorted. After getting all that done the car still pulls to the left? Also if i have my hands at 9 and 3oclock (sorry only way to describe it) i have to hold the wheel at more like 8 and 2oclock just to keep the car in a straight line? If that makes sence?
Any ideas to what is causing it?
Cheers
hi
PostPosted: Thu May 10, 2012 12:58 pm Up
bad tires!!
slymambo
PostPosted: Thu May 10, 2012 1:07 pm Up
Tires are all good, recently both changed?
hi
marc206
PostPosted: Thu May 10, 2012 1:12 pm Up
hmm nothing wrong with the wishbones or what not?
L5_UKS
Check the tyres are on the right side as most tyres are directional, tyre pressure or if you say you have already had the wheel alinement done it could be that something is bent on the suspension.
PostPosted: Thu May 10, 2012 3:43 pm Up
ESP steering angle sensor should really be reset when the wheel alignment is adjusted.
slymambo
PostPosted: Fri May 11, 2012 9:26 am Up
How do you reset the esp steering angle sensor?
hi
gpvecchi
PostPosted: Fri May 11, 2012 1:33 pm Up
ESP steering angle just reports 0 position on the steering wheel (sensor is inside COMM 2000). If steering is always centered, it's always in zero position, no matters if you have toe in or out of 1mm or 2mm...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
