Latest: sparrowdclxvi
Overall: 17139
Online Now [202]:
Visitors: 201
Today: 29769
Total: 113101165
Forums › The Car › 206 Problems › clutch thudd?
clutch thudd?
bezford
PostPosted: Tue Apr 24, 2012 1:58 pm Up
my 206gti 2002model is slowly deteriating seemingly in the clutch?ive only had it 3 wks and its on its way out i fear.Gear changes are ok but every time i am not very carefull when changing up into second gear there is a big thudd as the gear goes in?if i try and make an even slightly fast change the thudd presents itself as i go from first to second as i release the clutch in second.The other changes seem ok but even them might be getting worse ive just noticed and will have to wait and see?Whats causing the thudd to occur?any ideas?thanks...
R.HYDE
will-sussex
PostPosted: Thu May 10, 2012 5:58 pm Up
Could it be engine mounts? Maybe drive the car slowly and carefully with bonnet up and see if engine is leaping about.
206SW 1.4HDI
Deckchair5
PostPosted: Fri May 11, 2012 1:34 am Up
Yes I agree it sounds a lot like engine mounts. The rear of the engine gearbox to body tie bar mount will be well worn by now if that is still the original 10 year old mount and any excessive movement there will make it very hard work to change gear smoothly, particularly noticeable with the more powerful gears of 1st to 2nd
DeadEyePaul
PostPosted: Fri May 11, 2012 1:38 am Up
How?? The bonnet covers the windscreen when open?
Deckchair5
PostPosted: Fri May 11, 2012 2:00 am Up
Ha! Maybe hire an olympic sprinter to run alongside?
On mine you could feel the movement by holding the gearshift or even looking at the gearshift with power on/off in 2nd. It takes surprisingly very little play on the rear gearbox mount (mine had play only of a few mm) to produce really nasty end of gearchanges and I was also getting severe judder when reversing at low rpm
A new rear gearbox mount made an enormous difference. Felt like a new car
PostPosted: Fri May 11, 2012 2:20 am Up
What have you been smoking? Never heard something so stupid.
OP please do not do this...
DeadEyePaul
PostPosted: Fri May 11, 2012 2:37 am Up
Even if you found someone that could run alongside his vision will be slightly impaired due to bouncing up and down from running. Rofl hilarious
gaffa786
PostPosted: Fri May 11, 2012 4:44 am Up
Would be a funny scene to watch lol have to say. But you could stick your head out the window Very Happy
Jammie_1989
PostPosted: Fri May 11, 2012 5:59 am Up
Mine does this and also has clutch judder. Usual a sign that the clutch is getting old. Get a garage to have a look to be sure.
206 gti 180
martinius88
PostPosted: Fri May 11, 2012 6:23 am Up
I had pretty much exactly the same thing, and it was a rear lower engine mount!
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
will-sussex
PostPosted: Fri May 11, 2012 5:30 pm Up
what I mean is of course, with an assistant, pull the car forwards a couple of feet, and back again , with the bonnet up. (Or take bonnet off of course)
206SW 1.4HDI
Deckchair5
PostPosted: Sat May 12, 2012 1:57 am Up
To be honest, the movement at the top of the engine is so small you'd have a job to spot a worn rear mount as the other engine mounts are quite high so it doesn't rock much up there, it's all down low
If you put the car securely up high enough and have a good look at the rear mount then if it looks like this with gaps and cracks between the outer casing and the inside rubber then it is knackered
