Online Now [122]:
Visitors: 121
Today: 40822
Total: 117604412
Forums › The Car › 206 Talk › Oil change/level
Oil change/level
Go to page Previous  1, 2
SinfulDesignCom
PostPosted: Mon May 14, 2012 2:48 pm Up
broadblaster wrote:
According to the owner’s manual the regular 2.0L engine found in the GTi and the CC requires 4.25 litres of oil when changing the oil and filter, and the GTi180 requires 5.3 litres of oil for the same task. The manual is also quite strict on the use of 5W40 synthetic oil only for the GTi180
I stand corrected on the level - thank you, but use of 5w40 is a judgement call. Bear in mind that as engines build up the miles, the tollerance of the components will decrease meaning that thinner oil will get through piston ring gaps etc easier - meaning oil burning and eventual glazing... then new liners time!
I would say 10w40 for engines that have covered 50k+. But this is only my opinion - at the end of the day an oil change every 4-6k miles whatever the grade (within reason) will keep an engine in good nick..
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
broadblaster
PostPosted: Mon May 14, 2012 2:51 pm Up
tbh i tend to use a 10w-40w myself
on a back road playing
andyleep
PostPosted: Mon May 14, 2012 2:56 pm Up
Thanks, I used 5W40 but not 5.3 litres! lol. Will check in the morning when it has all settled
SinfulDesignCom
PostPosted: Mon May 14, 2012 3:03 pm Up
Please report back so we have an answered thread.
I wouldn't worry too much dude. You will soon know if you are burning oil! Just keep an eye on the level every coupla weeks... assuming you have the right dipstick.. LMAO
andyleep
PostPosted: Tue May 15, 2012 12:12 pm Up
I had the wrong dipstick - got a GTI 180 one today and its a fair bit shorter! The level now reads about half way on the dipstick - and for the amount of oil I put in yesterday, that would be about right Smile I like getting these little imperfections sorted. But, as suggested, the electronic one must be faulty/inaccurate. Thanks for your time guys
broadblaster
PostPosted: Tue May 15, 2012 12:17 pm Up
no probs fella glad you got it sorted out.
SinfulDesignCom
PostPosted: Tue May 15, 2012 1:21 pm Up
thanks for reporting back. Just a heads up - the oil level sensor for the 180 is a few bucks shy of 50 squid. Buy a non genuine at your risk...
andyleep
PostPosted: Thu May 17, 2012 1:09 pm Up
Another oil issue I am concerned about.......
I'm guessing the oil light should come on when you turn the ignition on, then go out again (as the battery, airbag, esp lights etc do). Mine doesn't come on at all
SinfulDesignCom
PostPosted: Thu May 17, 2012 2:22 pm Up
Check the bulb in the instrument cluster. If there was an electric fault it would normal come on and stay on.
If the bulb works its time to check your sensors.
PostPosted: Sat May 19, 2012 2:04 pm Up
All 206's Don't have a light for oil when you turn the ignition on as the battery and airbag,..etc.
It only goes on if there is something wrong with the oil in your engine,such as a bad and clogged filter,no oil,and such things related to oil.it will go on with the stop flashing and a beep Smile
Page 2 of 2
