Latest: Makomeister18274
Overall: 17122
Online Now [60]:
Visitors: 59
Today: 11912
Total: 97759860
Forums › The Car › 206 Problems › Replacing shock
Replacing shock
206dturbohdi
PostPosted: Wed May 16, 2012 1:28 pm Up
Have found some useful info on this site about replacing a front shock.
My question is, will a front passenger shock and spring from a 1.4 petrol 206 fit on my 2.0 HDI DTurbo?
If it fits will the spring or shock be too soft?
Many thanks
HDI
PostPosted: Wed May 16, 2012 1:31 pm Up
It will fit but it wont be right. Front dampers on the GTi are the same as the 2.0 HDi.
206dturbohdi
PostPosted: Wed May 16, 2012 1:37 pm Up
Many thanks Edward. Had choice between 1.4 and 2.0 shock. The 1.4 shock was much better condition, but if it isn't right i'll give it a miss.
