Posted: Fri May 18, 2012 12:13 pm |
Not sure if its due to the change of alloy/wheel size but im pretty sure it is,my speed reads around 20% out (too high) which i THINK is also illegal/mot failure currently. Is the only way to correct this by paying an extortionate rate for a garage to plug into the ecu and reset the wheel size parameters?
Just wanted to check this before i go in and do it incase the guys taking me for my pay-cheque
Oh,its a 206 quicksilver as the sig says lol
| Joined the GTi massive 10/1/13
Goodbye lairy Pugani (quicksilver 1.4) | |
Posted: Fri May 18, 2012 12:16 pm |
well i got 17inch on mine and i do the speed limit past speed cameras and never get flashed
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Fri May 18, 2012 12:26 pm |
Trade Rating: +36
Mines 5mph out. No issues with MOT and I just adjust my speed accordingly. Never bothered me so wouldn't pay out the money to get it sorted.
Posted: Fri May 18, 2012 12:30 pm |
5mph aint too bad,but 20% out at 70 is a big difference. i can compensate easilly enough,but in turn its also bumpin up the mileage on an already high mileage pug. just wondered if there's another way
Posted: Fri May 18, 2012 12:32 pm |
Do they even check your speedo on an MOT as they don't drive the car do they. I heard that a sat nav speed is just as accurate as the one on the car?
Posted: Fri May 18, 2012 12:43 pm |
GPS is a lot more accurate than the speedo on constant speed. Speedo is more accurate on harsh acceleration.
Them calculators are inaccurate and shouldn't be trusted.
Posted: Fri May 18, 2012 12:48 pm |
Really? Because when I changed my alloys and comapared the speedo change to my GPS it was on song with the calculator I posted.
But of course I'm an idiot and that calculator should be ignored...
Posted: Fri May 18, 2012 12:49 pm |
Depends on your speed sensor
Posted: Fri May 18, 2012 12:54 pm |
Do you have a sat nav that has a speedo and compare it to that
Posted: Sat May 19, 2012 5:24 am |
MOT doesn't check speedo because they don't drive the car.
Posted: Sun May 20, 2012 9:50 am |
Well atm I have 195/55 15'' and when I do 70MPH on the speedo the GPS shows I'm doing 66-67MPH.
| 2001 Peugeot 206 2.0 HDi 90 D TURBO in China Blue (98-01) [57 MPG] | |
Posted: Mon May 21, 2012 12:47 am |
thats normal for the speedo to over read
Posted: Mon May 21, 2012 8:19 am |
That's sounds about what I get.
Posted: Sun Jul 08, 2012 10:27 am |
yeah,that caluclator doesnt work for me,it says speed on 30mph then real speed is 29.59mph,when actually it closer to speedo on 30 then real speed is 24-25 lol,and it gets bigger as you go
