Online Now [423]:
Visitors: 421
Members: 1
Today: 44540
Total: 154741836
Forums › The Car › 206 Problems › horn not working, airbag light flashing still
anton1989
PostPosted: Sat May 19, 2012 3:57 pm Up
Trade Rating: +16
Airbag light started flashing few days ago now my horn does not work? Works on the stalk just not on the middle of the steering wheel though?
DeadEyePaul
PostPosted: Sat May 19, 2012 3:59 pm Up
I didn't know the stalk sounds the horn?!
Davies
PostPosted: Sat May 19, 2012 4:00 pm Up
Does on a preplex Smile
Poppy, My 2.0 HDI Dream Wink
anton1989
PostPosted: Sat May 19, 2012 4:06 pm Up
Trade Rating: +16
good job really I'm sure its an m o t failure if the horn does not work
PostPosted: Sat May 19, 2012 4:09 pm Up
Spool snapped.
PostPosted: Sat May 19, 2012 4:13 pm Up
Lee wrote:
Spool snapped.
Best fault on the preplex is when the spool shorts the drivers airbag wiring & fires the airbag when the horns pressed Laughing
anton1989
PostPosted: Sat May 19, 2012 4:42 pm Up
Trade Rating: +16
MrBSI wrote:
Lee wrote:
Spool snapped.
Shocked nothing but car trouble this month at least with the 206 its all easy stuff, the vw on the other hand Confused
anton1989
PostPosted: Sat May 19, 2012 4:49 pm Up
Trade Rating: +16
Lee wrote:
Spool snapped.
where can I get a new one?
PostPosted: Sat May 19, 2012 5:02 pm Up
Not all. Wink
PostPosted: Sat May 19, 2012 5:05 pm Up
never used the horn b4
PostPosted: Sun May 20, 2012 2:00 am Up
I've got one you can have for £7.50 delivered.
If your horn works by pressing the end of the stalk, then you have a 306 stalk fitted. Nice simple mod tbh.
anton1989
PostPosted: Sun May 20, 2012 3:03 am Up
Trade Rating: +16
is it new? Local scrappy has one but don't really want a second hand one
PostPosted: Sun May 20, 2012 3:34 am Up
Second hand. Removed off one of my GTis
QuArTz
PostPosted: Sun May 20, 2012 6:21 am Up
Trade Rating: +16
This fault sounds similer to the fault I had with my Multi-plex horm/airbag set up.
£698 later, turned out I needed a new comms unit and BSI.. Sad
anton1989
PostPosted: Sun May 20, 2012 7:12 am Up
Trade Rating: +16
Ok, if the one from the scrappy is no good will be touch. Cheers
