Online Now [516]:
Visitors: 515
Today: 161478
Total: 154542529
Forums › The Car › 206 Problems › A lot of oil around rocker cover
nemesislee
PostPosted: Mon May 21, 2012 11:24 am Up
I have a lot oil coming from around the head gasket. The rubber is cracked around the corners and all around it there is oil. Do I need to replace the rocker cover? If so is it an easy job?
peugeot 206 silver 1.4ltr lx
andyleep
PostPosted: Mon May 21, 2012 11:45 am Up
Just replace the rocker cover gasket, easy job.
PostPosted: Mon May 21, 2012 12:00 pm Up
Torque the rocker cover fixings correctly on refitting else you will bend the rocker cover ruining it & also cause a nice new oil leak Laughing
nemesislee
PostPosted: Mon May 21, 2012 1:04 pm Up
When torquing the bolts back on how do I know when to stop? I hear it a lot but not sure will it require a special tool? Lol
PostPosted: Mon May 21, 2012 1:07 pm Up
Borrow a torque wrench OR dont go mad with the ratchet.
PostPosted: Mon May 21, 2012 1:29 pm Up
Replace the gasket,and borrow a torque wrench,you can get the data of torque from Auto Data,this is the best you can do,but get the original gasket ,not the replacment one.
SinfulDesignCom
PostPosted: Mon May 21, 2012 3:02 pm Up
torque on cam cover is next to nothing - about 15lft/lb I think. If you can't get a torque wrench, tighten using one finger on the ratchet or spanner and work from center. start finger tight and then tighten each a little at a time. and make sure the mating surface is totally clean - brake cleaner is good...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
nemesislee
PostPosted: Mon May 21, 2012 5:27 pm Up
Am I right in thinking that to just replace the rubber seal it's more than just removing the two visible bolts take of the cover then bolt it back on? I have yet to look I'm my Haynes about this. Lol
nemesislee
PostPosted: Mon May 21, 2012 5:35 pm Up
This is the dreaded thing lol
PostPosted: Tue May 22, 2012 8:53 am Up
Get rid of the non genuine oil filer cap & loose that w**ky breather filter while your at it.
nemesislee
PostPosted: Tue May 22, 2012 9:17 am Up
the breather pipe aint all there lol and what do you mean none genuine oil filer cap?
-Dave-
PostPosted: Tue May 22, 2012 9:23 am Up
Trade Rating: +36
[Fgjk
Ex 206 Owner.
-Dave-
PostPosted: Tue May 22, 2012 9:24 am Up
Trade Rating: +36
The oil filler cap you have on it isn't a standard part. It looks like a universal one that may not be fitting correctly. A proper one won't set you back a lot.
Ex 206 Owner.
nemesislee
PostPosted: Tue May 22, 2012 9:25 am Up
oh yeah lol never realised it was different why would that be? its been on there since i brought it
nemesislee
PostPosted: Tue May 22, 2012 9:26 am Up
That might explain idling issues i have when up hills etc :S il look into getting a proper one now. thing is though ...... why the hell is it not the original one :s
