Online Now [582]:
Visitors: 581
Today: 123398
Total: 150724767
Forums › The Car › 206 Problems › Electrical fault blown nearly every fuse in the car
ramigojag
PostPosted: Thu May 24, 2012 12:37 pm Up
My bootlight wasnt working so i went to change it as i pushed the new bulb in it sparked abit.
when i tried to start the car it wouldnt go so i did some looking around and the ignition coil fuse was in tact but the fuel pump wasnt so i swapped that out still nothing.
anyway on further inspection nearly every mini blade fuse has blown in the inside fuse box and the engine fuse box.
im lost anyone think of whats happend any chance i could have fried the BSI?
thanks
PostPosted: Thu May 24, 2012 12:40 pm Up
You've shorted a lot of things, as you'll have touched the positive feed to the earth, that is why you'll have blown everything.
Disconnect the battery correctly, and check/replace all fuses.
ramigojag
PostPosted: Thu May 24, 2012 12:54 pm Up
Cheers for the help the only reason ive stopped is ive run out of fuses so ill have another go at it tomorrow
