Posted: Tue Feb 21, 2012 5:40 pm |
Get someone to unplug and reconnect each of the temperature sensors and pull gently on the wires. In fitting the exhaust they may have dislodges something.
Posted: Tue Feb 21, 2012 6:11 pm |
i change the thermostat on my 206 without draining it, yes the fluid leaks out but put a clean tray underneath and catch the water, then just tip it back it the sensor itself can be changed without losing any fluid. The Thermostat is about £10 and the sensor £15. Have a look to see if there are two sensors near the thermostat, a brown one for the temp (not all have this but mine does) and a green one for the ECU. It might be worth checking the hoses and the expansion tank too. If its not losing water then it should be relatively simples
| 206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out | |
Posted: Wed Feb 22, 2012 2:38 pm |
Well proud of myself, gave the job a go myself, purchased a new Thermostat this aft, Halfords price £23 (pffft you can keep ya stat thanks very much) sourced one for £13 from Andrew Pages, anyway fitted it all okay and now both hoses get warm the radiator gets warm and i noticed the fan also works now too, so i gave myself a big pat on the back. I would like to thank everyone for their input, i couldn't have done it without you all.
Thanks again guys.
Debs.
Posted: Wed Feb 22, 2012 2:44 pm |
206DAG wrote: |
Well proud of myself, gave the job a go myself, purchased a new Thermostat this aft, Halfords price £23 (pffft you can keep ya stat thanks very much) sourced one for £13 from Andrew Pages, |
£13 for a thermostat
Posted: Wed Feb 22, 2012 3:57 pm |
Well done - good on you. And is the temp gauge now nice and steady?
PS: Networkrail are now recruiting apprentices for next years intake and looking to increase the number of women on the scheme. Voted best apprenticeship in the whole UK in 2008.
Posted: Wed Feb 22, 2012 8:26 pm |
MrBSI wrote: |
206DAG wrote: |
£13 for a thermostat |
ye bargain compared to halford price of £23
Posted: Wed Feb 22, 2012 8:30 pm |
thanks kandlbarrett
All steady for now but i will take it on a run in the morning and see what the gauge does, fingers crossed it doesn't do the same as before.
Posted: Thu Feb 23, 2012 10:07 am |
Have you put coolant in as well?
Posted: Thu Feb 23, 2012 10:49 am |
206DAG wrote: |
MrBSI wrote: |
206DAG wrote: |
ye bargain compared to halford price of £23 |
I'd rather go straight to Peugeot / Citroen main dealer & save money on both those prices
Posted: Thu Feb 23, 2012 2:16 pm |
yes Steve i topped up the coolant and bled the system after replacing the stat thanks for the reminder though
Posted: Mon May 07, 2012 5:36 am |
well 2 months since i fitted the new Stat now and the car has been running fine without any problems in regards to the temp gauge. So the stat was the problem. Thanks for everybody's input, much appreciated. Debs
Posted: Fri May 25, 2012 12:57 am |
Sorry to wake up an old and finished thread.
But while your car was being a dog, you didn't notice if you could turn the radiator fan by hand?
My cars over heating at the moment (our few days of summer) and the temp doesn't fall, only climbs while stationary. Driving along it drops back to 80ish.
I can't turn the radiator fan by hand either.
No problems if no1 replies as it is an old thread now.
Posted: Fri May 25, 2012 1:12 am |
What temp does it rise to? As to me your car sounds normal.
Posted: Fri May 25, 2012 1:37 am |
@MrMorris: Sounds more like your fan relays are screwed and the fan isn't kicking in, which is a common problem. (I have this same problem, but have not yet had chance to look at it)
Posted: Fri May 25, 2012 2:56 am |
My temps rise all the way to Max and red STOP comes on.
Like I say, the fan is impossible to turn by hand, blades feel like they will snap before fan turns.
Relays are th electric plugs at bottom of radiator??
Sorry for hijacking this thread
