Latest: Andyblue64
Overall: 17123
Online Now [424]:
Visitors: 423
Today: 37933
Total: 98406667
Forums › The Car › 206 Problems › Front speakers dont fit.
Mephisto
PostPosted: Fri May 25, 2012 4:26 am Up
I bought some infinitys and the just dont fit, i Think they are hitting the back of the speaker cage..What the best thing to do?
A, Chop the back of the cage mount
B, Put a wooden templete to bring the speaker out a bit, but would this rattle?
Help Please!
Blah Blah Blah
PostPosted: Fri May 25, 2012 4:34 am Up
Be warned - the front window passes very near to the back of the speaker plastic cage, the glass can hit the back of the speaker once the cage is removed if the speaker is to deep.
anton1989
PostPosted: Fri May 25, 2012 4:42 am Up
Trade Rating: +16
B is the best thing to do, also improves sound.
as mrBSI said A might course you problems, i did this and my window only just clears the back of my speaker.
Mephisto
PostPosted: Fri May 25, 2012 5:46 am Up
Cheers, I made 4 wee spacers to push the speaker out, seems to do the trick.. Just need to trim the doorcard so it doesnt touch.Jobs a good un
Blah Blah Blah
PostPosted: Fri May 25, 2012 6:16 am Up
Only one thread is needed
PostPosted: Fri May 25, 2012 7:09 am Up
Option B.
Also use the round foam on each driver front as fitted by the factory.
This greatly reduces rattle and improves sound quality believe it or not.
Do not chop the plastic cage or remove it as it also acts as a tuned 'baffle' for the rear of the driver.
