Latest: DanDan17
Overall: 17128
Online Now [54]:
Visitors: 53
Today: 4418
Total: 100524379
Forums › The Car › 206 Talk › crystals headlights question
20619d
PostPosted: Thu May 31, 2012 1:20 pm Up
i just plugged them in my car that came with frosted lights. all works fine but when i put full beam on the dipped light goes out is that ment happen or is it ment stay on?
PostPosted: Thu May 31, 2012 1:23 pm Up
You need a BSi update to get it activated
PostPosted: Thu May 31, 2012 1:24 pm Up
If yours is multiplexed you need a bsi tweak, if its preplex you need a relay or adapted stalk.
20619d
how much will that cost and do i 100% need it
20619d
PostPosted: Thu May 31, 2012 1:28 pm Up
forgot put mine has all the wireing to plug lights straight in to car
Martind
PostPosted: Thu May 31, 2012 1:29 pm Up
Would it not just need an extra earth?
PostPosted: Thu May 31, 2012 1:30 pm Up
Is yours multiplex or pre plex?
20619d
PostPosted: Thu May 31, 2012 1:32 pm Up
i have no idea how do i tell
Martind
PostPosted: Thu May 31, 2012 1:33 pm Up
I know 20619d is an multiplex 206
20619d
PostPosted: Thu May 31, 2012 1:34 pm Up
how u tell??
PostPosted: Thu May 31, 2012 1:42 pm Up
Radio stalk on the steering wheel, if yours is deffinatally multiplex its a bsi tweak that's needed
Martind
PostPosted: Thu May 31, 2012 1:47 pm Up
Even if the car has got both plugs
Hes got the plug for crystals and the plug for frosted?
PostPosted: Thu May 31, 2012 3:48 pm Up
Or you could use the light switch from a GTi. They have a differently wired stalk, so will work without any updates etc. PM Lee or Mr.BSI about it.
PostPosted: Thu May 31, 2012 3:49 pm Up
Only works on pre plex, multiplexed like the op is a complete comm2000 unit controlled by the BSi
Matt
PostPosted: Thu May 31, 2012 4:53 pm Up
Trade Rating: +32
You need the h4-h7 wiring harness or get the settings changed (if the option is available on your car)
