Latest: DanDan17
Overall: 17128
Online Now [63]:
Visitors: 62
Today: 5614
Total: 100525572
Forums › The Car › 206 Talk › crystals headlights question
Go to page Previous  1, 2
20619d
PostPosted: Fri Jun 01, 2012 2:16 am Up
Matt wrote:
You need the h4-h7 wiring harness or get the settings changed (if the option is available on your car)
my car has both wire harness sat on the car so it was just case of plug in and play
PostPosted: Fri Jun 01, 2012 2:38 am Up
You need the BSi tweak to get them working, no need for different harness
Matt
PostPosted: Fri Jun 01, 2012 6:02 am Up
Trade Rating: +32
Some cars do have the wiring for both but you still need the setting updating if using the wires on the loom.
If you get the harness with the relay you don't need it.
I done the same as you (swapping from h4 to h7) but i bought the harness aswell. But then I got Lee to update my setting and then sold the harness as I didn't need it anymore.
Abzynthe
PostPosted: Fri Jun 01, 2012 6:13 am Up
East Area Rep - Abzynthe
Its an easy fix with Peugeot planet, You just go into the bsi, select visual/lighting and select present for twin beam or something like that. 10 minute max job Smile
20619d
PostPosted: Fri Jun 01, 2012 6:38 am Up
how do u get peugeot planet?
Abzynthe
PostPosted: Fri Jun 01, 2012 7:52 am Up
I got mine off ebay, but its expensive. Especially if you only want to turn the lights on lol
20619d
PostPosted: Fri Jun 01, 2012 8:02 am Up
dam lol pug garage goin cost loads
Abzynthe
PostPosted: Fri Jun 01, 2012 10:49 am Up
I had a quote of £69 to turn my CD changer on, and its essencially the same process. im sure it could be cheaper at a dealer, I think they were just trying to crew me lol.
You going to any shows? I can do it for a tenna for you Smile
20619d
PostPosted: Fri Jun 01, 2012 11:51 am Up
nope show s**t at mo show no shows for me lol
Elreidy
PostPosted: Sat Jun 02, 2012 3:57 am Up
Cost me £50 for soldering in the h7 connectors instead of h4 and changing the bsi, shop around the first place quoted me £100!
Page 2 of 2
