Posted: Fri Jun 01, 2012 2:16 am |
Matt wrote: |
You need the h4-h7 wiring harness or get the settings changed (if the option is available on your car) |
my car has both wire harness sat on the car so it was just case of plug in and play
Posted: Fri Jun 01, 2012 2:38 am |
20619d wrote: |
Matt wrote: |
my car has both wire harness sat on the car so it was just case of plug in and play |
You need the BSi tweak to get them working, no need for different harness
Posted: Fri Jun 01, 2012 6:02 am |
Trade Rating: +32
20619d wrote: |
Matt wrote: |
Some cars do have the wiring for both but you still need the setting updating if using the wires on the loom.
If you get the harness with the relay you don't need it.
I done the same as you (swapping from h4 to h7) but i bought the harness aswell. But then I got Lee to update my setting and then sold the harness as I didn't need it anymore.
Posted: Fri Jun 01, 2012 6:13 am |
Its an easy fix with Peugeot planet, You just go into the bsi, select visual/lighting and select present for twin beam or something like that. 10 minute max job
Posted: Fri Jun 01, 2012 6:38 am |
Abzynthe wrote: |
Its an easy fix with Peugeot planet, You just go into the bsi, select visual/lighting and select present for twin beam or something like that. 10 minute max job |
how do u get peugeot planet?
Posted: Fri Jun 01, 2012 7:52 am |
I got mine off ebay, but its expensive. Especially if you only want to turn the lights on lol
Posted: Fri Jun 01, 2012 8:02 am |
dam lol pug garage goin cost loads
Posted: Fri Jun 01, 2012 10:49 am |
I had a quote of £69 to turn my CD changer on, and its essencially the same process. im sure it could be cheaper at a dealer, I think they were just trying to crew me lol.
You going to any shows? I can do it for a tenna for you
Posted: Fri Jun 01, 2012 11:51 am |
Abzynthe wrote: |
You going to any shows? I can do it for a tenna for you |
nope show s**t at mo show no shows for me lol
Posted: Sat Jun 02, 2012 3:57 am |
Cost me £50 for soldering in the h7 connectors instead of h4 and changing the bsi, shop around the first place quoted me £100!
