Posted: Sat Jun 02, 2012 1:54 pm |
I've just fitted a new wishbone to my gti 180 today and whilst doing it the passenger side driveshaft just fell out! once id put it back in and replaced my wishbone i road tested the car only to discover the gearbox was leaking oil out from.round the drive shaft.
i have one stripped the driveshaft taken it out and there doesn't seem to be any clip to keep it in place could someone tell me.if there is suppose to be a clip inside the box or on the end of the drive shaft thanks
| | ![](images/spacer.gif) |
Posted: Sat Jun 02, 2012 2:11 pm |
they just push into place iirc but you may have done the oil seal in they are cheap enough to replace from stealers.
Posted: Sat Jun 02, 2012 2:20 pm |
definately sounds like the oil ring. They should stay put during the job, but it might be that gone that it fell out. Always better to forward plan and grab a new one when you are there for the sake of a couple of squid...
Posted: Sat Jun 02, 2012 2:32 pm |
I just had a new seal on drivers side. Cost £60 labour and parts.
| I\'m Steve got a 2003 verve. | |
Posted: Sat Jun 02, 2012 2:44 pm |
the oil seal is just a tenner from dealer
Posted: Sat Jun 02, 2012 2:49 pm |
Make sure it's right in the box if it's not then it will leak
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Sat Jun 02, 2012 2:54 pm |
imjeeves wrote: |
Make sure it's right in the box if it's not then it will leak |
anyone still thinking of gearboxes? ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
