Online Now [913]:
Visitors: 912
Today: 107432
Total: 152747754
Forums › The Car › 206 Problems › 206 GTi Handbrake snapped ?????
MrMorris
PostPosted: Sun Jun 03, 2012 9:54 am Up
Hiya guys, right. I'll explain.
I was leaning into my car yesterday to pull the handbrake up, my knee (long on going problem) gave way and I fell, ofcourse I was holding onto the handbrake at the time and I ripped the handbrake right up, it made a kind of loud click noise and now the handbrake is slack. Very slack. It kind of wobbles about freely when not applied at all.
It can go nearly 90 degrees up, it still clicks into places, can count about 14-15 clicks. it stops the car rolling away still (only just), but its weak.
Normally it would only go about 6-7 clicks, and felt nice and tight. And no chance of the car moving at all when handbrake was applied.
Any ideas?
Cheers lads, Mark.
PostPosted: Sun Jun 03, 2012 10:23 am Up
Replace it?
BobiksWRC
PostPosted: Sun Jun 03, 2012 10:44 am Up
Sounds like one of handbrake cables snapped. I had this problem last summer. It snapped where it conects to the drum brakes
Pedal to the metal
spike_202
PostPosted: Sun Jun 03, 2012 10:53 am Up
Yer this happend to me The cable had snapped right on the end I did both at the same time then you know they are both new.
**spike's project**
TEAM:+200bhp
MrMorris
PostPosted: Mon Jun 04, 2012 3:35 am Up
Ok, cheers lads, so if I buy a new cable from eurocarparts for like £13, it goes from the handbrake down the car, splits into two, one for each rear brake?
Or do I have to buy 2 cables?
Sorry, complete noob on cars Sad
PostPosted: Mon Jun 04, 2012 3:38 am Up
For the 206 handbrake setup you need 2 cables, they are both attached to the bracket behind the handbrake lever.
BobiksWRC
PostPosted: Mon Jun 04, 2012 7:03 am Up
Here is from "How to.." www.206info.co.uk/Foru...28151.html
Helped me alot..
Pedal to the metal
