Online Now [333]:
Visitors: 332
Today: 68257
Total: 155858878
Forums › The Car › Request a how-to › how do you fill the eolys fluid tank /replace fuel senor cap
shawb
PostPosted: Sun Jun 03, 2012 11:24 am Reply with quote Up
Hello
Can somebody tell me which connector you attach the filler tube to in order to fill the eolys tank please? I have 3 options - two are on a black cap (left of right - which one goes to the fue tank and which one goes to the eolys tank?) and the other is on the middle of the tank (i would of thought this one would let the fluid thats left in the tank out if disconnected?)
I also need my fuel sensor cap replacing and I am unsure as to how to do this....
Any help would be greatly received!
Ben
ben
shawb
PostPosted: Sun Jun 03, 2012 12:40 pm Reply with quote Up
found out about filling the tank - now just need some help on replacing the fuel cap sensor please.
info on how to fill eolys tank
www.peugeotforums.com/...-kit-b.jpg
ben
Squeaker
PostPosted: Sun Jun 03, 2012 3:07 pm Reply with quote Up
The fuel cap sensor plugs into the filler pipe near the top, the wire runs down the filler pipe, plugs into something on top of the fuel tank and then runs off to somewhere near the eolys tank.
I'm breaking mine, i took the fuel sensor off when i removed the tank, i imagine you might be able to get to the plug on the top of the tank via the plastic hole under the rear seats.
  Quick Reply
Username:
Message:
Quote the last message
