Latest: Andyblue64
Overall: 17123
Online Now [309]:
Visitors: 308
Today: 25907
Total: 97973229
Forums › The Car › 206 Problems › Squeaking front passenger wheel?
kit325
PostPosted: Tue Jun 05, 2012 12:22 pm Up
My 206 front left wheel start to make a loud squeaking noise (only at low speed 10mph -25mph). It passed MOT about 3 weeks agop without any problem.
After driving above 50mph for a few minutes, this annoying sound will go away. However next day when u start driving, u can hear the same squeaking sound.
Anyone know or experienced similar problem? Any advice or help will be appreciated, thz!
kit
ukskater01
PostPosted: Tue Jun 05, 2012 12:26 pm Up
Does the squeaking change when you brake?
kit325
PostPosted: Tue Jun 05, 2012 12:34 pm Up
nope! Loud at 5-10mph when coming to a stop. Can't hear any when drive above 30mph, sound disappear even at slow speed when i drive above 50 mph a few minutes.
kit
PostPosted: Tue Jun 05, 2012 1:37 pm Up
Could be the wheel bearing on the way out.
kit325
PostPosted: Wed Jun 06, 2012 4:51 am Up
Any idea how much it cost to replace one in garage?
kit
R_D_G
PostPosted: Wed Jun 06, 2012 5:55 am Up
I had one done about 2 months ago and it was just over £100 for the bearing to be done, some people wanted £200 for it so best to shop around.
Jensen
PostPosted: Wed Jun 06, 2012 10:16 am Up
You can get it done alot cheaper than that, you just to know the right people, have a search on here and I'm sure there will be someone close that can do it, my mate got his 180 front bearings done for £70 including parts from some guy down the road Smile
kit325
PostPosted: Thu Jun 07, 2012 10:52 pm Up
Might try and strip down the disc brakes and clean it up to see if it works, but as u guys said might be the wheel bearing.
Tempted to change it my self unfortunately don't have a press to release the bearing from the hub. Will this more difficult than changing the wishbones?
kit
kit325
PostPosted: Sun Jun 17, 2012 3:26 pm Up
Updated!
Just spend 3 hours cleaning the front disk brakes and the suspension, found out that at my rear nearside wheel is not spining smoothly cause tyres actually is taching the inner arch and tyre wall being rub away a bit. I swap the rear tyre to the front and the squaking noise is gone.
kit
PostPosted: Sun Jun 17, 2012 3:30 pm Up
did you fit the wrong tyre/wheel?
