Latest: sparrowdclxvi
Overall: 17139
Online Now [127]:
Visitors: 126
Today: 34921
Total: 113562312
Forums › The Car › 206 Problems › Any though why the engine blown up?
Ry206an
PostPosted: Sat Jun 09, 2012 10:50 am Up
I had a similar thing happen on my old car (Megane, unfortunately) turns out a valve spring shattered.
What\'s wrong with it now?
spike_202
PostPosted: Sat Jun 09, 2012 11:10 am Up
Over revved thus having a scenario of a floating lifter thus bent a lifter leading to the rest of the damage that's what happend to mine nealy 2 years back.
**spike's project**
TEAM:+200bhp
macj
PostPosted: Sat Jun 09, 2012 11:30 am Up
Its the valve........ probably broke its head off and mashed piston. It would explain why the plugs damaged too. I would say the cam is partly responsible here. Too tight a tolerance to the piston..... miss one gear and its contact time
PostPosted: Sat Jun 09, 2012 1:49 pm Up
is that mean you could partly blame the lifter too?
i never like the idea of running wild cam with hydraulic lifters
D4NTP
PostPosted: Sat Jun 09, 2012 2:40 pm Up
I'd say it was just a dodgy valve. there's too much of the plug left for it to have been that. High revving cam on old valves and its sheared and dropped in.
spike_202
PostPosted: Sat Jun 09, 2012 5:08 pm Up
I have 280 cams with hydrolic lifters it's just my subframe Witch was at fault!!! (gear pivot) snapped thus putting my gear in 1st insed of 3rd witch over reved leading to blowing my engine
**spike's project**
TEAM:+200bhp
macj
PostPosted: Sun Jun 10, 2012 2:16 am Up
Yep.....that would do it
spike_202
PostPosted: Sun Jun 10, 2012 4:13 am Up
Lol it did do it alright so if you ever have your sub frame off just check the weld that holds the gear pivot...learn from my expensive mistake.
**spike's project**
TEAM:+200bhp
macj
PostPosted: Sun Jun 10, 2012 4:23 am Up
I am suffering a blown engine ATM as well.... very expensive Crying or Very sad
PostPosted: Sun Jun 10, 2012 5:12 am Up
what happen? Sad
macj
PostPosted: Sun Jun 10, 2012 5:28 am Up
At a rally a few weeks ago.... 2nd gear right hander-short straight-2nd gear left hander opening long..... I held it on the limiter between the two corners and it let go on the exit of the left opener as I changed to 3rd..... oops Crying or Very sad
PostPosted: Sun Jun 10, 2012 5:39 am Up
doesn't sounds good.....
macj
PostPosted: Sun Jun 10, 2012 5:52 am Up
Its not good........ engine is at the builders and he cant start assembling it till Monday.... and its FCS next weekend and its booked to go out on track Embarassed
spike_202
PostPosted: Sun Jun 10, 2012 6:35 am Up
That's why I didn't even buy a ticket as I'm not sure mine will be done in time I'll have the custom work done just not a remap as the waiting list is like 3weeks so getting that done in July.
**spike's project**
TEAM:+200bhp
PostPosted: Sun Jun 10, 2012 6:46 am Up
did you source a 2nd hand engine or you rebuild it with parts?
Page 2 of 3
