Latest: Mr-Koekwaus
Overall: 17125
Online Now [320]:
Visitors: 319
Today: 48126
Total: 99666126
Forums › The Car › 206 Problems › Warning lights
Warning lights
Karu
PostPosted: Sat Jun 16, 2012 9:06 pm Up
My warning lights were flashing on my 03/2001 build 206 and I discovered the positive battery terminal wasn't tight, fixed. But when I turn on my lights most lights light up on the dash. I believe the dash has moved back slightly and that allows all the icons to be lit up from the few globes that are supposed to be on. Can anyone explain how I remove the dash so I can fit it properly? Thanks, Kru
archoil works!
PostPosted: Sun Jun 17, 2012 12:38 am Up
You sure your battery or alternator aren't on the way out?
Karu
PostPosted: Sun Jun 17, 2012 5:26 am Up
I will have to get them tested, although it always starts with ease. Which aspect of these problems is the clue? Also, when I turn on the ignition to accessories to listen to the radio the battery light comes on, I was thinking it's a French thing.
archoil works!
PostPosted: Sun Jun 17, 2012 5:35 am Up
Its designed to do that, its to remind you the ignition is in the accessory position.
PSA have been doing that for 25+ years.
