Posted: Sat Jun 16, 2012 9:06 pm |
My warning lights were flashing on my 03/2001 build 206 and I discovered the positive battery terminal wasn't tight, fixed. But when I turn on my lights most lights light up on the dash. I believe the dash has moved back slightly and that allows all the icons to be lit up from the few globes that are supposed to be on. Can anyone explain how I remove the dash so I can fit it properly? Thanks, Kru
Posted: Sun Jun 17, 2012 12:38 am |
You sure your battery or alternator aren't on the way out?
Posted: Sun Jun 17, 2012 5:26 am |
I will have to get them tested, although it always starts with ease. Which aspect of these problems is the clue? Also, when I turn on the ignition to accessories to listen to the radio the battery light comes on, I was thinking it's a French thing.
Posted: Sun Jun 17, 2012 5:35 am |
Karu wrote: |
Also, when I turn on the ignition to accessories to listen to the radio the battery light comes on |
Its designed to do that, its to remind you the ignition is in the accessory position.
PSA have been doing that for 25+ years.
