Online Now [403]:
Visitors: 402
Today: 104665
Total: 156211410
Forums › Tuning, Modification & Legal › Project Cars › **Spike's project ft pug1off**
Go to page Previous  1, 2, 3 ... 9, 10, 11 ... 18, 19, 20  Next
PostPosted: Sun Jun 17, 2012 2:05 pm Up
I was thinking of having the PAS pump on mine switched on by my Omex. I.e. it doesn't get switched on until a certain engine speed it reached - maybe 500rpm.
spike_202
PostPosted: Sun Jun 17, 2012 2:14 pm Up
Yer could be done if you wanted mine just turns on and primes on the final instrument possision, just should of had a 40amp fuse to alow for the initial spike in power on start up.
Are you using the vauxhall pump or the pug one?
**spike's project**
TEAM:+200bhp
PostPosted: Sun Jun 17, 2012 2:34 pm Up
I'm going to try a Saxo/106 pump and get the bracket welded to the standard airbox bracket.
spike_202
PostPosted: Sun Jun 17, 2012 3:06 pm Up
I don't think it's strong enough mate, that's were I have my oil catch tank and just about ok for that. I've had the 106 bracket customised to fit in the corner along with a rubber mount to reduce the vibrations then bolted to the frame.
**spike's project**
TEAM:+200bhp
spike_202
PostPosted: Wed Jun 20, 2012 2:27 pm Up
Seats fitted v.happy with the final look and also hold you spot on round corners enjoy...
I don't even need to change the bars for steel as I used 8mm thick alloy and worked a treat.
**spike's project**
TEAM:+200bhp
usher
PostPosted: Thu Jun 21, 2012 12:53 pm Up
nice making your own seat mounts, is there much benifit from messing with the rad and pas pump for the trumpets to be bigger
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
spike_202
PostPosted: Thu Jun 21, 2012 1:30 pm Up
Thanks usher, it was quite easy 2nd, It's open to interpretation mate it depends on how deep you want to get into it,... I ran NO filter for 3years as the rad was in the way so nothing could get in to the intake. BUT sucked hot air in as a downside. It revs well having less belt travel and pulleys to go around but I have a L&B fly wheel any way so revs quite quick any way. Now I've got cold air going into the inlet instead of hot air that can't be bad. I also think the elec conversion has a lot better feel to it than the standard PAS. You can use socks or a big universal sock that goes round the 4 trumpets but for what I wanted I needed the standard pump out.
On the trumpet subject you'll losses some hi end bhp but gain more mid range tourqe witch in my case I'll be able to use better. I'll be taking the 65's to the rollers to see the difference in power curves between the
lengths.
Hope that helps abit lol
**spike's project**
TEAM:+200bhp
DeadEyePaul
PostPosted: Mon Jun 25, 2012 3:26 pm Up
Cool glad you got the seats in! You noticed you can take on roundabouts more aggressively? Very Happy
spike_202
PostPosted: Mon Jun 25, 2012 3:35 pm Up
Lol it's suprising you can, well it just feels like you have more support and keeps you nice and strapped in.
**spike's project**
TEAM:+200bhp
PostPosted: Mon Jun 25, 2012 3:49 pm Up
Seats look awesome, I saw someone selling the same ones (I think) on sax p ages ago
Glad to see you did it the same way I would have done it, cheapest most effective way really
spike_202
PostPosted: Mon Jun 25, 2012 4:05 pm Up
It is Harry soooo simple to nice and low, but not to low, that was my main worry but all is good just gotta fit the harness eye hooks into the exhaust tunnel then the harnesses can go in and can be removed in seconds.
Then my list left is:
Wait for the correct carpet to arrive.
Fit grp n mounts.
Fit my 180 TB's and higher the rear.
Remap booked for next month.
Then I'll be happy.......for now supose save for the next stage Twisted Evil
**spike's project**
TEAM:+200bhp
usher
PostPosted: Tue Jun 26, 2012 6:37 am Up
so would you recomend moving the rad when i do the itb convertion, which rad did you use in the end i know you were talking about a custom one
project thread WIP
garage
FAQ
206 gti firedance
spike_202
PostPosted: Tue Jun 26, 2012 6:52 am Up
Nar I used the standard rad mate I didn't do the work I got pug1off as they do all my car mods, thers no point in moving the rad down if your not going to do the elec pas conversion as that alows you to use a back plate filter. Or buy an air box like Edward from Jenvey...you'll get a good price if you say I sent you Wink
For the price of doing the mods what I have just done, for a Dailey runner I wouldn't bother. Id just get an air box like edwards, but this is conning off the road next year and doing the rest that I have planned.
**spike's project**
TEAM:+200bhp
usher
PostPosted: Tue Jun 26, 2012 6:56 am Up
i would do it myself if i was to do it, have thought about making my own air box and using a backplate filter like you have now, cald air is my main objective as hot air cant be goot from the rad, i would want the itbs in a box so suppose it all depends on clearance when fitted as i say ill make my own air box, cant justify the cost of the CF one longmans make
project thread WIP
garage
FAQ
206 gti firedance
spike_202
PostPosted: Tue Jun 26, 2012 7:05 am Up
Cool I've used a 50mm deep carbonfiber one as wanted it to match my engine cover ect also to cover most of the 80mm trumpets.
You'll need to get a elec pump,donor car for the bracket to be taken from,get a hi presure hose for the connection to the rack and a loom to feed and fuse it all. I also used an aftermarket hi flow motosport fan for the rad
Also if you go the way I have you'll need bonnet pinns as I had all the fan&surround removed for maximum flow but you bonnet has nothing to clip to so that's why I needed pins I don't mind tho as I think they look mint.
**spike's project**
TEAM:+200bhp
Page 10 of 20
