Latest: sparrowdclxvi
Overall: 17139
Online Now [106]:
Visitors: 105
Today: 14725
Total: 113427424
Forums › The Car › 206 Problems › 2 problems. Oil in inlet manifold and fan behind glovebox
206boyracer
PostPosted: Mon Jun 18, 2012 12:38 am Up
Hi everyone!
yesterday I took out my throttle body for cleaning. When I had it off and I looked down into the inlet manifold I noticed a puddle of oil in the bottom. It's not very deep but definitely oil not water. Im assuming it has got in there from the breather hoses over time. Will this cause any harm to leave it or do I need to remove the manifold and clean it out? If so how do I do this.
Before I removed the throttle body I sprayed carb cleaner into the throat with the engine running. This was about a month ago tho and the car is not being driven at all could it be residue from that still?
Question two. When under my glovebox Saturday I noticed a small fan hanging down about an inch and half across. It is loomed with the glovebox lighting switch. I couldn't see and obvious places where it located but it looks like a small cooling fan for something electrical rather than passengers. Does anybody know where it locates.
Thanks Dan.
206 GTI 138.
PostPosted: Mon Jun 18, 2012 5:28 am Up
Do you have digital climate control? If so the small fan will more than likely be the cabin temp sensor.
206boyracer
PostPosted: Mon Jun 18, 2012 6:03 am Up
Yeh it's digital climate control. Is the little fan supposed to be located somewhere? Or just dangling above the footwell? Would the sensor spin like a little fan then?
206 GTI 138.
PostPosted: Mon Jun 18, 2012 6:21 am Up
See the little holes in the passenger air bag? It's supposed to live behind there Wink
206boyracer
PostPosted: Mon Jun 18, 2012 6:30 am Up
Ah ideal. Il pop it back up there tonight. Thanks. Must have come loose when I pulled my glovebox out back along. Any ideas on the oil in the inlet manifold? It's a gti 138 if that makes a difference.
206 GTI 138.
206boyracer
PostPosted: Mon Jun 18, 2012 12:14 pm Up
Thanks leeThr that was exactly what it was. What a pain to get located tho.
206 GTI 138.
PostPosted: Mon Jun 18, 2012 12:38 pm Up
I wouldnt worry about the oil.
206boyracer
PostPosted: Mon Jun 18, 2012 12:55 pm Up
Ok thanks. I'm assuming it just got in there from the breather hose.
206 GTI 138.
