Latest: heikkisj
Overall: 17126
Online Now [39]:
Visitors: 38
Today: 7728
Total: 100205382
Forums › The Car › 206 Problems › Central locking odditys
greenpug2222
PostPosted: Wed Jun 20, 2012 7:37 am Up
Hi,
Im having problems with the central locking. THe driver door used to work all other doors but not will not, it only locks itself. I guess this is why im having probs with the key fob too, all locks go down then come back up.
Help needed please.
why wont you work??????????????????? ARGH F**k it!!!!!
Jack123
PostPosted: Wed Jun 20, 2012 11:06 am Up
You more then likely have a faulty Solenoid somewhere.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
greenpug2222
PostPosted: Wed Jun 20, 2012 12:47 pm Up
ok,
Ive doen a search but can not find the info i need..... can someone help please?????
1, MY lock wireing has a red clip i need to pull up----do i have the old or new type conector?
2, Am i right in reading i have to disconect each lock 1 by 1 to find the culprit?
3, Does anyone know where i can by them new... apart from pug dealer?
4, Do the locks etc from another model fit the 206 as on ebay there doesnt seem to be much choice at good price.
5, how much new are they from dealer (approx)
Cheers
greenpug2222
PostPosted: Fri Jun 22, 2012 6:19 am Up
Does anyone know the above before i start wasting money?
Deckchair5
PostPosted: Fri Jun 22, 2012 10:53 am Up
What happens when you sit inside and push a door internal lock catch down?
If all the locks then lock and stay down then that's a good lock/solenoid
If they all bounce back up then you've found the bad one that is locking but signaling that it's open to all the others so they copy the signal and open too
You need to let people know your car model / age and whether your car is mux or not otherwise it's difficult to help you as there are different systems
greenpug2222
PostPosted: Sun Jul 08, 2012 9:06 am Up
The car is a 2000 w reg 206 1.4lx model 3 door model.
I can push down either inside lock catch and only that door will lock and not bounce up. At the moment im having to lock the the driver door manually and just push the passenger nob down from the inside as well as keeping the boot locked.
Any more help appriciated.???
greenpug2222
PostPosted: Wed Aug 15, 2012 6:59 pm Up
Anyone else help with this?
Also the interior light doesnit work when I open the driver door.
PostPosted: Thu Aug 16, 2012 3:20 am Up
That tells you the problem is with the drivers door lock motor OR the wiring to it.
dan.brown.120393
PostPosted: Thu Aug 16, 2012 4:27 am Up
Have you checked your fuses?
Dan Brown
greenpug2222
PostPosted: Thu Aug 16, 2012 7:28 am Up
All fuels seem fine. I'll try get another lock from eBay and go from there
greenpug2222
PostPosted: Thu Aug 16, 2012 7:29 am Up
All fuses seem fine. I'll try get another lock from eBay and go from there
