Latest: jtq4u
Overall: 17141
Online Now [327]:
Visitors: 326
Today: 44753
Total: 113951798
Forums › The Car › 206 Problems › Snapped airbag loom!!
Mephisto
PostPosted: Mon Jun 25, 2012 5:21 am Up
I was removing my air bag and managed to snap all the plugs off the loom can I simply solder the plugs back on??
Blah Blah Blah
PostPosted: Mon Jun 25, 2012 5:23 am Up
Depends on if the pins are still in the plugs with wire to solder on to.
PostPosted: Mon Jun 25, 2012 5:27 am Up
Probably not, just replace the spool or coms unit if you have one
PostPosted: Mon Jun 25, 2012 5:38 am Up
Ouch, its multiplexed, thats going to be one expensive mistake if it was the drivers airbag you where trying to remove.
Will be a new com2000 unit.
You will struggle to solder the airbag wires back together on a com unit.
Mephisto
PostPosted: Mon Jun 25, 2012 5:43 am Up
Argh it's multiplexed, can I just get a new spool?i don't fancy getting a comms unit
Blah Blah Blah
PostPosted: Mon Jun 25, 2012 5:50 am Up
Nope, spool is part of the com unit.
Mephisto
PostPosted: Mon Jun 25, 2012 12:05 pm Up
Magic, how hard is it to fit a comm unit?
Blah Blah Blah
PostPosted: Mon Jun 25, 2012 12:17 pm Up
Steering wheel removed, take the plastic trim of around the steering column, undo the clamp at the back, unplug the comm then unclip it to remove it.
Mephisto
PostPosted: Mon Jun 25, 2012 12:20 pm Up
Cheers, are comms unit specific to vehicle type? Ie would i need to get one for a 1.4 deisel, or would anyone fit a 52 plate multiplexed car?
Blah Blah Blah
PostPosted: Mon Jun 25, 2012 12:23 pm Up
You need one from a 206 for a start, either match up the functions from your old com unit OR look on the back of it as there are id numbers on it.
OR pm me the cars VIN & ill look up the correct part number on Peugeot Service Box.
Mephisto
PostPosted: Mon Jun 25, 2012 1:02 pm Up
cheers,I'll have a look tomorrow
Blah Blah Blah
