Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 64
Today: 22443
Total: 100420610
Forums › The Car › 206 Problems › 206 coolant missing
206 coolant missing
keikei
PostPosted: Mon Jun 25, 2012 4:43 pm Up
Hi,
I have peugeot 206 1.4 1999. I am loosing the coolant, no leaks can be seen and oil looks good - no coolant in there, also no white smoke in exhaust.
Spark plugs were checked in garage today as car is misfiring a little.
Today on a short trip home the temp gauge went bit over 90 and than straight into red in like 5 sec. Stopped for 2 - 3 min started again and temp. was back to normal.
At home checked the coolant level after engine cooled down a little and it was fine. Heated it up to working temp. and it did not overheat. Left it for another half an hour and the coolant was gone again from the reservoir?
Where could the coolant go?
PostPosted: Mon Jun 25, 2012 4:50 pm Up
this looks like you got air in the coolant system
keikei
PostPosted: Mon Jun 25, 2012 4:59 pm Up
that would make sense - when I was removing the cup it let quite a lot of air out.
How to get that air out?
PostPosted: Mon Jun 25, 2012 5:18 pm Up
look at the 2 black pipes on the right of the engine that go through the bulkhead, there's a valve on there.
PostPosted: Tue Jun 26, 2012 7:49 am Up
Just bled the air out of my cooling system after doing the timing belt kit & water pump.
Bleed screw on the coolant pipe next to the bulkhead & also a blank you can remove just behind the thermostat on the housing ( early 206's might have a 2nd temp sensor screwed in here )
keikei
PostPosted: Tue Jun 26, 2012 11:18 am Up
Thanks for your replies.
I will take it to garage in the morning. Im still afraid that it will be head gasket - but at least I have a hope for air in the system.
Peugeot 206
keikei
PostPosted: Wed Jun 27, 2012 2:42 am Up
Thermostat needed to be replaced as it was stuck and coolant was blown out through radiator cup.
Peugeot 206
