Latest: Andyblue64
Overall: 17123
Online Now [324]:
Visitors: 323
Today: 6863
Total: 97954233
Forums › The Car › 206 Problems › New Trick
New Trick
PostPosted: Wed Jun 27, 2012 9:33 am Up
Ghosty wrote:
called the aa out as i have home start + roadside + relay (basically everything i can get)
and its the turbo thats gone, so called the warrenty company and the turbo is not covered anyway Sad :(
however found a garrett T15, re-manafactured (with 12 month warrenty from garrett) for £400 on ebay
cgi.ebay.co.uk/ws/eBay...1034847404
what do you guys recon
get a quote from local turbo rebuild company Wink
Ghosty
PostPosted: Wed Jun 27, 2012 9:56 am Up
i doubt there is one in swindon, but im off to google it now
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Wed Jun 27, 2012 11:06 am Up
Turbo needs to be fitted correctly else it wont last 5 minutes.
Sump has to come of, oil filter in the bango has to be replaced, needs to be run on the correct oil etc etc.
spike_202
PostPosted: Wed Jun 27, 2012 11:50 am Up
True, you can't just bolt it on and drive like normal it has to be 'broken in' so is the head gasket ok? or does it needs turbo and a head gasket job? You could always get your mate to aulter the invoice for your needs to pass onto the warrantee company?
**spike's project**
TEAM:+200bhp
sicskate
PostPosted: Wed Jun 27, 2012 2:03 pm Up
Trade Rating: +13
Try turbo technics or dynamic turbos.
307 1.4hdi Smile
PostPosted: Wed Jun 27, 2012 2:10 pm Up
turbo technics charge a fortune so as the labor cost too
Baggiesfan01
PostPosted: Wed Jun 27, 2012 2:38 pm Up
I work for a Turbo rebuilders in Birmingham we cover most if not all makes and i know we cover peugeot. heres the website.
www.gap-turbos.com/about.html
Pug 2.0 HDI owner
PostPosted: Wed Jun 27, 2012 3:58 pm Up
Turbo Technics do the job correctly & with a decent warranty.
nellyhaggis
PostPosted: Wed Jun 27, 2012 4:16 pm Up
You sure it's the turbo?
Mine did the same the other day and it was a wire off a sensor on drivers side of the engine inter cooler to inlet manifold area.
It wasn't letting air through and so it was chucking loads of smoke out.
Just a thought that's all.
Also if your going down the route of a new turbo why not spend a bit more and go for a hybrid turbo!
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Wed Jun 27, 2012 4:18 pm Up
no sure if it is worth on a 1.6HDi Rolling On The Floor Laughing
PostPosted: Wed Jun 27, 2012 4:48 pm Up
If your going to repair then might as well do a proper job Laughing
Ghosty
PostPosted: Fri Jul 06, 2012 9:35 am Up
quick update,
it was just the turbo that was gone, car has done 114k so was near its end of life anyway. i have sourced a re-built garret t15 from turborebuild.co.uk for £395 with free postage, they offer a 12 month warrenty, and i called to see if it mattered that i had the engine mapped and dpf removed (he actually said it was the best thing i could of done), and they can tell if the damage to the turbo is from the mapping or from another failure.
they also offer a £50 refund for sending my old turbo.
so as its just the turbo that has gone (oil seals iirc) that is all that would need to be replaced. so it arrives on tuesday, as a matter of course im getting the oil feed pipe changed, as well as a lot of internal cleaning of the inlets, exhaust ect. also going to run it on correct grade cheapo oil till it cleans up, then going to use proper stuff.
i know cheappo oil is not the best idea but not wanbting to pay silly money for oil that will be thrown out and its only function would be to take the remaining carbon out of the system
PostPosted: Fri Jul 06, 2012 11:18 am Up
26 quid for 5L of oil surely wasn't silly money
and this will ensure your turbo won't blown up again.
darratt78
PostPosted: Fri Jul 06, 2012 11:32 am Up
Be good to see another hdi-gti around Swindon mate best of luck! My turbo was changed on 110k (when I bought it) and 4k later is running great! Had to happen sooner or later.
206 hdi GTI
ARRAN
PostPosted: Fri Jul 06, 2012 1:26 pm Up
Off topic, but where abouts you guys from in Swindon? I'm from Wootton Bassett!
See my project here.
Page 2 of 3
