Latest: Mr-Koekwaus
Overall: 17125
Online Now [353]:
Visitors: 352
Today: 11988
Total: 99630053
Forums › The Car › 206 Problems › XSI Faults
XSI Faults
mask0017
PostPosted: Wed Jun 27, 2012 11:39 am Up
Got hold of a 53 plate low mileage 206 XSI
Starting work to get it on road again, the car has been sitting for around 10 months
Got some faults showing with pug planet i'm no to sure about
Airbags
BSI
Also ABS Fault the abs seems to have shut down have managed to get it working intermitintly.
Did manage to get rid of the pass deactivation fault and side airbag fault but came back as soon as abs fault kicked in again..
Anybody got any ideas where to start with these
mask0017
260 LX 2.0 HDI
mask0017
PostPosted: Wed Jun 27, 2012 4:06 pm Up
Bump
46 views and nobody got any ideas
Crying or Very sad
260 LX 2.0 HDI
PostPosted: Wed Jun 27, 2012 4:15 pm Up
ABS fault is probably a split ABS ring on one of the driveshafts, check them, As with airbag faults, has the car ever been bumped? I would take it for a 50 mile drive if you can. I get airbag faults if my battery has gone flat, a drive usually sorts it out. Also, what condition is the battery? A low or dying one will cause havoc!
mask0017
PostPosted: Wed Jun 27, 2012 4:24 pm Up
ABS rings are all ok tested all the sensors aswell all near same reading,
Battery should be ok
new discs and pads been put on front and back but brakes feel real spongey.
Gonna power bleed them 2 moz be a while before it can get a hoof on the road no bumpers or lights in it just now.
The abs has gone from tottaly dead to intermitint working with a few runs up and down farm road but can't get up above 15 mph on that road
260 LX 2.0 HDI
Big_Rich180
PostPosted: Thu Jun 28, 2012 2:50 am Up
I had a speed fault on my 180 and it turned out to be the wiring to the ABS sensor that was broke.
