Latest: sparrowdclxvi
Overall: 17139
Online Now [142]:
Visitors: 141
Today: 1660
Total: 113529448
Forums › The Car › 206 Problems › Management light...
Management light...
evilmunkey87
PostPosted: Thu Jun 28, 2012 4:35 pm Up
So... I picked up my lovely GTi today, love it!! However, the chap rang me last night saying that the drive belt had started to screech as he drove home from having the MOT done.
Knocked a few quid off the car to cover it and I am getting the new belt fitted tomorrow evening .
I drove from Thatcham (where I bought the car) to Bristol (where my gf goes to uni) and then to Torquay, where I live. No problem at all, drove like a dream but then as I drove home from poker earlier, the engine management light flickered a few times then came on solid... but there is no difference in noise, no loss of power, no change in the handling or anything... a little confused to say the least.
Anybody experienced this before? Or maybe know why it would be?
Thanks Smile
206 GTi
PostPosted: Thu Jun 28, 2012 4:45 pm Up
Your p**sing in to the wind until you scan it for fault codes.
2001 onwards are EOBD so cheap / easy to scan.
PostPosted: Thu Jun 28, 2012 4:46 pm Up
better to get the code read while you do the belt
evilmunkey87
PostPosted: Thu Jun 28, 2012 4:50 pm Up
fair enough, it is March 2001 registered so hopefully I can get it sorted tomorrow Smile Cheers
206 GTi
PostPosted: Thu Jun 28, 2012 4:52 pm Up
Diag socket is behind the dash flap towards the drivers right knee.
nellyhaggis
PostPosted: Fri Jun 29, 2012 12:48 am Up
Then just pop the code in google and pray!
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Fri Jun 29, 2012 2:47 am Up
Codes only point you where to start looking for the fault Wink
evilmunkey87
PostPosted: Fri Jun 29, 2012 10:11 am Up
Thanks for that, I am getting it checked out tonight. Light went off earlier then came back on again a short while ago.
Also cut out at lights a couple of times, hopefully its just a breather pipe or something come loose Smile
206 GTi
evilmunkey87
PostPosted: Fri Jun 29, 2012 3:01 pm Up
Done a fault read, failing spark plug apparently, got 4 on order changing them Monday, hopefully it will cure it Smile
Belt is all done now, management light has been off all evening which is good!
I have no display though, checked connections behind the stereo, everything seems fine, didn't have time to take the display off or anything but will check Monday when I'm at work...
206 GTi
PostPosted: Fri Jun 29, 2012 3:57 pm Up
On order? Most motor factors will have the Bosch plugs on the shelf. Even Halfrauds usually have them in stock. Even my local A1 store carries a range of Bosch plugs. I'd change them sooner than Monday if I could to avoid anything else failing if the plug gives out before hand.
