Latest: heikkisj
Overall: 17126
Online Now [71]:
Visitors: 70
Today: 15881
Total: 100194512
Forums › The Car › 206 Problems › Car Thinks Keys Still In Ignition
flurry
PostPosted: Thu Jun 28, 2012 7:59 pm Up
Hi Guys
I have a weird fault that just started today and I hope someone here has the answer to this one. Its to do with not being able to lock the car with the key fob.
Usually when I open the drivers door and leave the keys in the ignition a little chime goes off several times and stops when I take the keys out, however today I take the keys out of the ignition, get out of the car, shut the door and try to lock it using the keyfob and nothing happens. So then I open the door again and the chiming starts up again.
When I put the keys back in and out of the barrel a few times and started up the car and stopped it again (basically repeating the same thing I had already done) the weird problem kept reappearing. In the end I had to lock the car with the door lock and key.
I was thinking about maybe putting some wd40 down the barrel or maybe some graphite, any one got any ideas what would be nest?
Very Happy
206 GTi 180
Walton450
PostPosted: Thu Jun 28, 2012 11:51 pm Up
Mine does it from time to time. I just played around with the key in the barrel and pressed the buttons.
I\'m Steve got a 2003 verve.
PostPosted: Fri Jun 29, 2012 12:29 am Up
Known BSI software bug, Peugeot main dealer & software update if it bothers you.
OR
Reboot the BSI unit if your a cheapskate.
flurry
PostPosted: Fri Jun 29, 2012 1:09 am Up
Im pretty cheap so how do I reboot that myself?
Cheers Very Happy
206 GTi 180
Razor34
PostPosted: Fri Jun 29, 2012 5:57 am Up
There is a how to for this as it has been asked a million or more times. Use the search function and you will find it Very Happy
Ray
flurry
PostPosted: Fri Jun 29, 2012 6:12 am Up
ok thanks for your help Smile
206 GTi 180
