Latest: sparrowdclxvi
Overall: 17139
Online Now [127]:
Visitors: 126
Today: 21823
Total: 113549372
Forums › The Car › 206 Problems › Cable idenification 12v socket
QuArTz
PostPosted: Fri Jun 29, 2012 11:41 am Up
Trade Rating: +16
Picked this up from a 307 this afternoon, want to use it in the 206 as an extra 12v socket.
Could someone tell me what each cable is for?
I know the green/yellow cable is earth/-v but what is the purple and brown one for?
The brown one is thinner that the others..
mtempsch
PostPosted: Fri Jun 29, 2012 12:03 pm Up
I'd expect the purple to be for +12V to the the heater / center contact (as it''s heavier gauge). That and the ground should be all needed for a power outlet.
The brown might be for illumination - is there a bulb in the socket?
Edit:
According to this diagram there' s a bulb in the cig lighter (see object 98)
Looks like the bulb is lit when lighter is pressed in/heating (which explains me never having noticed it) Looks like the third wire connects the bulb to ground (most likely the BSI controlled delayed/dimming ground).
Silvermetallic 2004 206 RC
QuArTz
PostPosted: Fri Jun 29, 2012 12:17 pm Up
Trade Rating: +16
No.. there isnt a bulb in the socket, I suppose the plug is a generic plug for a 12v socket which could have illumination.
cheers for the help.
QuArTz
PostPosted: Fri Jun 29, 2012 12:26 pm Up
Trade Rating: +16
Yeah. I see that..
Nice one, thanks for the diagram
mtempsch
PostPosted: Fri Jun 29, 2012 1:36 pm Up
QuArTz wrote:
Yeah. I see that..
Ack... must be really tired... That 3rd wire doesn't go to ground, it's a +12V feed (the other end of the bulb is attached to the ground wire).
DeadEyePaul
PostPosted: Fri Jun 29, 2012 2:40 pm Up
From wiring a house plug perspective. Yellow/green is your earth, brown is power and that purple one is negative. Before playing with electrics d/n battery and put a fuse on the positive wire.
PostPosted: Fri Jun 29, 2012 4:00 pm Up
It's French so nothing is logical. Check continuity with a multimeter before making any connections.
Mattie-RS
PostPosted: Fri Jun 29, 2012 4:35 pm Up
Loooooool, this is for a car not a house. Two totally different systems
