Online Now [1002]:
Visitors: 1002
Today: 145345
Total: 151632888
Forums › The Car › 206 Problems › ESP/ASR not functioning?
gazwelshguy
PostPosted: Sat Jun 30, 2012 12:18 pm Up
Been to look at purchasing a 206 GTI 180 today. Can anyone tell me what ESP/ASR not functioning means.. It comes up on the trip computer screen
V REG PUG 206 GTI SP
PostPosted: Sat Jun 30, 2012 12:20 pm Up
It means the ESP / ABS isnt working.
Needs scanning with Peugeot Planet first.
It could be a simple cheap ABS sensor failure, cracked toothed wheel on a front drive shaft, low battery voltage etc OR it could be a faulty ESP unit & that would cost mega money to fix!
Could also be a shagged com 2000 unit & there also mega money to replace on a GTI 180.
gazwelshguy
PostPosted: Sat Jun 30, 2012 12:27 pm Up
Will ask him tomorrow to have it checked first might be an idea. Cheers for the reply
Gaz
PostPosted: Sat Jun 30, 2012 12:28 pm Up
It could be a cheap simple fix OR it could be a bloody expensive repair, scan it with Peugeot Planet & you should get the answer Wink
gazwelshguy
PostPosted: Sat Jun 30, 2012 12:31 pm Up
Could this mean it will fail an MOT?
Schumi
PostPosted: Sat Jun 30, 2012 4:05 pm Up
If your ABS is working well than wheel ring and some other stuff is fine. It could be Steering Angle Sensor or wrong calibration. If you remove steering rack and reinstall. And made tracking than generally you need connect to PP2000 and recalibrate center point of steering wheel.
2005 206 RC RED
Headtrauma
PostPosted: Tue Aug 07, 2012 10:40 am Up
My asr/esp warning comes on every time it rains, I got really scared..
It's a faulty speed sensor on mine although you'll need to find a friendly garage to get a diagnosis of your specific problem.
206 Gti 180sp\r\nStill scares me Smile
