Latest: sparrowdclxvi
Overall: 17139
Online Now [459]:
Visitors: 458
Today: 30384
Total: 112418346
Forums › The Car › 206 Problems › Is it a strange 206 problem?
very_452001
PostPosted: Mon Jul 02, 2012 5:36 am Up
At random times whenever I start the car the engine turns off straight away regardless if its hold or cold. This is a Intermittent fault. Garage said map sensor needs replacing so got it replaced but problem still there.
Whenever I start the car in neutral where should the rev needle should be at?
I notice when i put electrical stuff on like radio, headlights, wipers etc during the engine on. the rev needle goes down a bit then up a bit. Like when the needle goes down you can feel it bout to stall then it doesnt and the needle goes back up and the same pattern repeat itself.
Why is that?
Regarding the engine turning off straight away problem, when i turn on the electrical stuff on before starting the engine, thats when the turning off problem is more likely to happen.
I dont think the battery is dead because if it is then the car would not start at all and I have to jump start it all the time which I dont.
Please advise. Cheers,
very_452001
DeadEyePaul
PostPosted: Mon Jul 02, 2012 5:44 am Up
sounds like your car is struggling to start from cold. could be your battery not holding enough charge to power all your accessories, or it could be an alternator or even the belt.
shadow
could be alternator and or battery is dying as not enough power to run the car and the electrics, i would check the battery 1st and then look at the alternator to see if it is charging.
206cc 2.0 allure
AzMan
PostPosted: Mon Jul 02, 2012 6:52 am Up
Why is that?
Sound like it's most surely a battery problem, either too much or too little current/voltage, my friends currently got that problem with his astra.
Change the battery and after driving it a few days, see if it persists, if it does could be your altenater.
2001, Silver 2Door, LX, 1.4
very_452001
PostPosted: Mon Jul 02, 2012 7:28 am Up
It happens regardless if hot or cold.
very_452001
shadow
PostPosted: Mon Jul 02, 2012 7:44 am Up
sounds like there is not enough cranking power in the battery you proberbly have 2/3 duff cells
206cc 2.0 allure
BigGreenDave
PostPosted: Mon Jul 02, 2012 7:56 am Up
Mine used to do after long periods of not being turned off while i was messing with it off road. Its just the battery that was dead and when i charged it i hadnt charged it long enough but i just kept it at 2000rpm for about 2min and it was fine again now i make sure its run everyday for at least 10mins so that i dont have this problem again.
F**k Scene YAWN
marc206
PostPosted: Mon Jul 02, 2012 10:07 am Up
what spark plugs you got?
very_452001
PostPosted: Mon Jul 02, 2012 5:56 pm Up
dont know, normal ones i think.
very_452001
swaynie
PostPosted: Mon Jul 02, 2012 6:32 pm Up
The question what should be asked is what ice you got if your drawing too much current revs will dip and it's clear your not very technically minded and I wouldn't worry at all tbh
If your offended by my posts call\r\n0800 I dont care Wink
nellyhaggis
PostPosted: Tue Jul 03, 2012 1:26 am Up
Battery. Mine something similar to this. It would also bring faults up for the airbags and abs etc.
I guess it was because all the power was being drained from the battery on start up.
New battery. Problemo solved.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Ash
PostPosted: Tue Jul 03, 2012 1:53 am Up
While you're at it, give the stepper motor a clean.
very_452001
PostPosted: Tue Jul 03, 2012 4:38 am Up
I'm a noob when it comes to mechanical terms. What is a stepper motor?
I took it to the same garage where I was told it was the map sensor and got it replaced. Now the same garage is saying is saying its the crank sensor that's causing it and they are charging me £80 to replace it.
very_452001
