Latest: Mr-Koekwaus
Overall: 17125
Online Now [123]:
Visitors: 122
Today: 23104
Total: 99408321
Forums › The Car › 206 Problems › Got Air conditioning Re-gassed but still no cold air?
very_452001
PostPosted: Tue Jul 03, 2012 12:30 pm Up
for the AC to work does the air intake slider has to be in the inside air circulate position or outside air position or either?
very_452001
PostPosted: Tue Jul 03, 2012 2:11 pm Up
Kwikfit do "no-fix, no fee" £50 for a fix or free if it doesn't work.
They purged and attempted to charge mine. That took 30mins approx but it wouldn't hold the charge so no fee.
PostPosted: Tue Jul 03, 2012 2:16 pm Up
doesn't matter.
AC will be on when you press it
very_452001
PostPosted: Tue Jul 03, 2012 4:43 pm Up
Seabook wrote:
doesn't matter.
mechanic told me it should be recycle air circulate position for the ac to work properly. what the hell?
very_452001
spike_202
PostPosted: Tue Jul 03, 2012 5:00 pm Up
Only to get it cold quicker and more controlled temp as it 'recycles' the air in the car instead of letting fresh air into the car from outside. That's why people say air con won't work if the windows open...yes it will but not v.effectively that's all.
**spike's project**
TEAM:+200bhp
very_452001
PostPosted: Wed Jul 04, 2012 3:31 am Up
So the mechanic was talking rubbish. The air intake slider can be in any position.
very_452001
spike_202
PostPosted: Wed Jul 04, 2012 3:36 am Up
Oh I thought you was asking about a digital one my bad, I'm not sure about the lower spec models, all I know is as soon as you press the ac button it's working, regardless were the slider possision is
**spike's project**
TEAM:+200bhp
PostPosted: Wed Jul 04, 2012 5:25 am Up
The car needs to go to an aircon specialist as several people have already mentioned in this thread BUT very_452001 cant be bothered.
Until someone that ACTUALLY KNOWS WHAT THERE DOING diagnosis the problem the aircon system will just stay non working.
There is only so much help you can give people BUT when they dont listen as they think they know better its just a waste of time Rolling Eyes
PostPosted: Wed Jul 04, 2012 5:01 pm Up
+1.
This guy doesn't even understand the difference between voltage and potential difference. He doesn't stand a chance fixing air con.
There is a joke in there a most should spot it.
very_452001
PostPosted: Thu Jul 05, 2012 3:11 am Up
Ok I go to a air con specialists. I live in birmingham. Are kwik fit air con specialists or con specialists?
very_452001
broadblaster
PostPosted: Thu Jul 05, 2012 12:37 pm Up
forget kwik fit fella just do a google search for air con specialist in your area
on a back road playing
very_452001
PostPosted: Thu Jul 05, 2012 2:57 pm Up
there's loads in the birmingham area. Which is the best in birmingham?
very_452001
broadblaster
PostPosted: Thu Jul 05, 2012 2:59 pm Up
the one that is the most local to you and gives a warenty on there work
very_452001
PostPosted: Thu Jul 05, 2012 3:11 pm Up
anyone from birmingham with reccomendations?
very_452001
very_452001
PostPosted: Wed Jul 24, 2013 8:52 am Up
Update: I took it to a air con specialist today and he connected a pressure gauge to it and told me there's no pressure. Thats all he told me.
My AC light comes on, fuses are ok.
When I press the AC button I dont hear any sounds or see the Rev dial moving.
I can see the radiator fan spinning regardless of AC button is on or off. I did this fan test when engine is hot. Or am I suppose to check the fan is spinning when engine is cold?
Im still confused whether I have a electrical or mechanical problem? No pressure or leaks means mechanical right? Yet I have symptons of electrical problem as well.
What is the commom diagnostic problem to AC failures when it comes to 206's in general?
very_452001
Page 3 of 5
