Latest: DanDan17
Overall: 17128
Online Now [49]:
Visitors: 48
Today: 26417
Total: 100501201
Forums › The Car › 206 Talk › Bsi replacement
Bsi replacement
agronom
PostPosted: Mon Jul 02, 2012 10:01 am Up
Hi, I try replace BSI today, the reason is indicator work on the half (The work properly to turn left, but not work tu turn the right) before indicator to left working fine but after few weeks it's start flashing look like one ofe the bulbs is missing. Now indicator sounds but they are not shows on dash board and not wworks outside. I found how to fix that problem. The problem can be in relay. it's need to replace. But I cant replace the BSI. Unscrew the BSI but I can it replace or take it off. Some thing just hold it. I try to move BSI in different locations but it doesnt help me. I try to do everthing like hire.
if any one can make a picture to have it's posible to take off or some thing else just let me know.
thank you
asdasda
Abzynthe
PostPosted: Mon Jul 02, 2012 10:55 am Up
East Area Rep - Abzynthe
What year is your car?
It may just be either the stalk or the Com2000.
Im pretty sure you cant just replace the BSI, especially with a second hand unit as its coded to your ECU so your whole car wont work unless its done properly.
agronom
PostPosted: Tue Jul 03, 2012 3:35 pm Up
2000 glx 1.4
asdasda
