Posted: Tue Jul 03, 2012 5:02 pm |
does everyone's car steam up really easily??
mine happens too much i think
Posted: Tue Jul 03, 2012 5:07 pm |
Change your pollen filter?
Posted: Tue Jul 03, 2012 5:09 pm |
spike_202 wrote: |
Change your pollen filter? |
had car serviced in march should they not have changed it
Posted: Tue Jul 03, 2012 5:10 pm |
gaffa786 wrote: |
spike_202 wrote: |
had car serviced in march should they not have changed it |
depends on if that was included in the service
Posted: Tue Jul 03, 2012 5:16 pm |
Seabook wrote: |
gaffa786 wrote: |
spike_202 wrote: |
depends on if that was included in the service |
And did you check? I do my own servicing BUT if I ever had to take it to a garage I'd still check what they have done.
Posted: Tue Jul 03, 2012 5:25 pm |
spike_202 wrote: |
Seabook wrote: |
gaffa786 wrote: |
spike_202 wrote: |
And did you check? I do my own servicing BUT if I ever had to take it to a garage I'd still check what they have done. |
i have no idea what the pollen filter looks like or where it is
Posted: Tue Jul 03, 2012 5:34 pm |
behind the drive side front strut (where the bonnet vent it)
Posted: Tue Jul 03, 2012 5:40 pm |
Seabook wrote: |
behind the drive side front strut (where the bonnet vent it) |
how would i know if it needs replacing will it look messed up?
Posted: Wed Jul 04, 2012 12:05 am |
Yer it will be dirty and full of crap lift the bonnet up and put your hand like into the gap and pull it out
Posted: Wed Jul 04, 2012 1:53 am |
You have to lift it up, twist it 90 degrees then pull it out, it should be white, but it will probably be black when you look at it.
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Wed Jul 04, 2012 2:07 am |
I doubt changing the pollen filter will make a difference.
Posted: Wed Jul 04, 2012 2:17 am |
E5GDM wrote: |
I doubt changing the pollen filter will make a difference. |
It will help tho
Posted: Wed Jul 04, 2012 2:33 am |
You've probably got moisture in the carpets or something, try leaving a de-humidifier in there for a few hours, failing that stick the aircon on lol
Posted: Wed Jul 04, 2012 3:40 am |
Big_Rich180 wrote: |
You've probably got moisture in the carpets or something, try leaving a de-humidifier in there for a few hours, failing that stick the aircon on lol |
Good call rich
Or some bags of silica gel
Posted: Thu Jul 05, 2012 2:01 am |
Dry out the car with a heater (I do it all the time, just make sure you do it safely)
Then learn to use aircon.
