Online Now [53]:
Visitors: 52
Today: 67447
Total: 117424216
Forums › The Car › 206 Problems › PPT30 no display
PPT30 no display
206boyracer
PostPosted: Wed Jul 04, 2012 10:40 am Up
Hi I have a problem with my PPT30 it lights up but no digits or information is displayed. I took my clocks out and repaired them recently and have not used the car since. It worked after I repaired the clocks but not now. Are the two linked up? Could I have damaged something behind the clocks when I had them apart. Or is it just bad luck and my ppt30 is now broke too?
206 GTI 138.
paul_c
PostPosted: Wed Jul 04, 2012 10:57 am Up
I'd say its fairly certain the two are linked. Why not take them out again and check the connection to the display unit? What did you need to do to the clocks, ie why were they broken to require a repair?
206boyracer
PostPosted: Wed Jul 04, 2012 11:09 am Up
The odometer wasn't working. It was because the ribbon was unsticking all I did was cut some card and wedge behind it.
206 GTI 138.
206boyracer
PostPosted: Wed Jul 04, 2012 12:58 pm Up
Just taken my clocks out and can't see anything damaged behind them on the board anywhere. The ribbon on the ppt is creased could this be it or would that just make the display bitty? It's not damaged all along just in the middle. God I hate electrics.
206 GTI 138.
paul_c
PostPosted: Wed Jul 04, 2012 2:46 pm Up
Sounds like you've damaged the ribbon cable and that's the problem. No idea how you're going to fix it - another cable from a scrappy?
206boyracer
PostPosted: Wed Jul 04, 2012 3:03 pm Up
Is there a fuse for the clock somewhere? Wondering / hoping it could just be that. Hope I don't need a new one. I haven't taken my mfd apart until now so can't understand how it's got damaged.
206 GTI 138.
